Old 02-23-2011, 09:39 PM   #1
Using a Ramset in old concrete
Hi,
I am putting a stud wall along the perimeter of my basement. I need to attach the sill to the floor. The concrete is 50 years old. A masonry bit wears out after about 2 holes.
I'm considering using a ramset ( fires concrete nails ). I'm wondering if anyone has experience doing this in old concrete. Do I need to worry about cracking the floor ?
Thanks.
Mike Mike is offline   Reply With Quote
Old 02-23-2011, 09:46 PM   #2
DIY Hack
Mr Chips's Avatar
Originally Posted by Mike Mike View Post
Hi,
Thanks.
i'd be more worried about fish hooking than cracking the crete. start with the lower powered load, like a green and see if that's enough. if not try a yellow next, don't go straight to a red without testing the others first
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 02-23-2011, 09:49 PM   #3
Thanks, didn't even know about that. Never used one before.
Old 02-23-2011, 10:50 PM   #4
remodeling pro
Hi,
Thanks.
Don't think you are going to have much luck with ramset in concrete that old.What are you using for a "masonry" bit and what type of drill? You will not succeed with the typical silver masonry bit or with a hammer drill or regular drill. Get a rotary hammer with a quality brand percussion bit such as a Hilti or Bosch then anchor the wall with split or deformed shank drive pins (they look like a fat nail with no point and have a kink in the shank).
After drilling the hole, you just drive them in with a hammer; a 2 or 3 pound machinist"s hammer works great for this, but a regular carpenters hammer with work ok.
troubleseeker is offline   Reply With Quote
Old 02-23-2011, 11:05 PM   #5
Love for Construction
<*(((><'s Avatar
I just got done remodeling a basement with my brother and father. The house was built in the 20's and I'm not quite sure when the basement slab was poured, but it looks pretty old. We used a ramset with 2-1/2" nails with I believe green loads. It worked just fine, about 10-20% of the nails had to be finished off with a hammer, but I thought that was pretty good given the age of the concrete.
Some advice that seemed to help us is be sure to have the ramset pressed firmly down against the sill when you hit it with the hammer. Also try and eliminate any rocking of the sill plate by chiseling any imperfections, if the sill is tight to the concrete and the ramset tight to the sill, it works really well, even on the old stuff.
Good luck.
-luke-
<*(((>< is offline   Reply With Quote
Old 02-24-2011, 06:37 AM   #6
Tool Geek
PaliBob's Avatar
.....The concrete is 50 years old. .....
That's not old concrete
Here is OLD Concrete
& Stay Safe
.....Bob Lavery
The Following User Says Thank You to PaliBob For This Useful Post:
tpolk (02-24-2011)
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 36 08-05-2012 11:43 AM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 09:47 PM
Tips For Pouring Concrete? Root issues? Thoughts? kronic24601 Building & Construction 5 02-14-2011 07:52 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
