Using Plastic Plus Insulation To Insulate An Interior Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-27-2008, 11:58 PM   #1
New owner, older house
using plastic plus insulation to insulate an interior wall
We are in the process of enclosing a small room--it backs up to another room. It previously had paneling inside and the other room has sheetrock. We want to "soundproof" the room a little more and someone told us to insulate all the walls and add a plastic barrier before we finish the sheetrock in the room.
Is there any problems with moisture building up in the plastic?
thanks
Taz38 is offline   Reply With Quote
Old 12-28-2008, 12:56 AM   #2
Registered User
Termite's Avatar
Plastic is a bad idea in my opinion. It doesn't breathe like a proper vapor barrier does. If you're using kraft-faced insulation I'd call it good.
Old 12-28-2008, 06:46 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
There is no reason for installing a plastic barrier in an interior wall, as you describe the layouts of the room.
Such a plastic layer, accomplishes absolutely nothing.
- Build Well -
Old 12-28-2008, 07:43 AM   #4
Thank you--that is what I was thinking, but needed confirmation
Old 12-28-2008, 07:48 AM   #5
not sure what kraft faced insulation is, but we're using R-13 (says rated for walls and basements). It's pink and has one side that has brown paper. So one side of the insulation is going to be touching the sheetrock--will this present any problems for the wall that is touching the insulation?
ETA: Nevermind I googled "kraft-faced" and it appears we're good!!
Old 12-28-2008, 08:05 AM   #6
BUILDER / REMODELING CONT
buletbob's Avatar
I don't know if you are aware of a sound deadening type of insulation that's available/ it works better then regular insulation. BOB
Old 12-28-2008, 09:08 AM   #7
insulation in a wall will help reduce sound transmission, but it is limited! Noise will still travel by way of the wall studs. If space will allow, I would recommend building another wall against the existing one. Only, off-set the new wall studs from those of the old wall. Then, add insulation. I did this between a bath room and a bedroom, I found this to be effective. Also, use 5/8" drywall, rather than 1/2" to further reduce the noise!
Old 12-28-2008, 12:36 PM   #8
Drywall contractor
Rewards Points: 1,070
Sound attenuation blankets (or "rock wool") is specifically used for sound deadening purposes. It would be the best material, though as pointed out it will not "sound proof" the wall. Wildie's method with the double wall will be the most effective method used with sound blankets. The insulation is available at a drywall supply yard. It is more costly than regular fiberglass and itches MUCH worse. If you decide to go with it, be sure to wear appropriate clothing (maybe disposable coveralls), safety glasses, and a mask. This may be more than you're looking for, but the R13 won't help matters much..... just muffles the sound.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 12-29-2008, 08:44 AM   #9
Mold!! Let's kill it!
Rewards Points: 2,012
Agreed, a plastic (or any other) vapor retarder is useless on an interior wall. The newer polyester batt insulation is supposed to have good sound attenuation qualities. Much better than fiberglass. If you can find it, I'd use that and forego the itchy stuff.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Exterior Wall Insulation require plastic barrier? BillyDIY Building & Construction 14 03-05-2009 11:19 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 06:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
