Old 11-11-2010, 05:52 PM   #1
using OSB to finish inside walls
Is it OK to use OSB to finish inside shop walls ??
Linds is offline   Reply With Quote
Old 11-11-2010, 10:08 PM   #2
jlhaslip's Avatar
certainly
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 11-12-2010, 01:16 AM   #3
Keep 'em dry, and painting over them MAY help w/ the off-gassing. You may want to look into that if you are going to be out there a lot. Does your code allow unprotected OSB/plywood? Codes are always a concern.
Old 11-12-2010, 10:53 AM   #4
Moderator
Termite's Avatar
If you're under the International Residential Code and are in a single family residence, there's no reason you couldn't use OSB or other wood panels on your walls. The only exception would be your garage walls, which require gypsum wallboard. OSB could be applied over the gypsum fire membrane though.
Cloth inside walls c00rdb General Discussion 9 07-27-2010 02:35 AM
Need to rebuild outside steps and walls coming from basement doug123 Building & Construction 31 05-03-2010 08:45 AM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 06:59 PM
Paint options for basement walls and floors 68tele Painting 8 10-28-2009 07:09 PM
Some walls rattle in my house if hit with something, I will explain inside posting zincmann Building & Construction 4 11-10-2008 04:05 PM
