Using I Joist On Floor Framing A Covered Porch - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-08-2011, 03:28 PM   #1
Using I joist on floor framing a covered porch
I'm planning to build a 3 season room on the back of my house and was wondering if I can us I joist for the flooring? The roof will be framed and supported buy 4x4 with concrete pillars 42" in the ground(frost line). The floor will span from my house to the post and will be opened to the ground and old patio 8+" of clearance. Can they be used being that close to the ground? Using I joist due to I want to run 18' with no xtra supports.
joenasnj is offline   Reply With Quote
Old 04-08-2011, 07:28 PM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
Hi Joe, I think there are way too many variables involved to be able to answer a question like that,
You should be talking to a designer, Architect or engineer for that answer.
Andy.
AndyGump is offline   Reply With Quote
Covered Porch over Basement leaks/rotting/repair Old College Try Building & Construction 10 11-13-2013 09:37 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
Covered front porch deck leaking smileydave Carpentry 2 09-24-2010 05:14 AM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 08:00 AM
want to build a covered porch marco fortino Building & Construction 1 07-23-2010 05:58 PM
