Using Glass Bricks For A Window - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-16-2010, 10:39 AM   #1
Rewards Points: 101
using glass bricks for a window
I have two identical windows, one in each of the bedrooms we're remodeling for our children, that are high, wide, and narrow. As each room already has a large and airy window in place, I thought it might add a nice touch to each room to replace the smaller windows with glass brick. As I've never done it before I could sure use some advice.
Firstly, do I assume correctly that the marble sill needs to be taken out so that the first row of bricks gets laid directly on to the brick?
Secondly and most importantly, what is the usual technique for making up gaps at either end or along the top? The windows measure 25 5/8 inches in height (including marble sill) by 52 1/4 inches in width.
I've attached some pictures to give a better idea of what we're dealing with.
Lastly, we also inherited a rear bathroom which had access to the pool deck, though at some point a previous owner decided to use glass bricks to close in the door. Is it easy to dismantle existing glass brick walls and to recycle the blocks?
Thanks in advance
using glass bricks for a window-dsc_9153.jpg   using glass bricks for a window-dsc_9155.jpg
timbo59 is offline   Reply With Quote
Old 03-16-2010, 12:03 PM   #2
kwikfishron's Avatar
Rewards Points: 998
Check out this link. I’ve used this product many times. Looks like glass but much easier to install and cleaner looking.
And no I'm not a Rep.
http://www.hy-lite.com/
kwikfishron is online now   Reply With Quote
Old 03-16-2010, 10:03 PM   #3
jlhaslip's Avatar
Rewards Points: 2,864
You would only be allowed to glass brick the windows of a bedroom around here if there was a second means of egress from those rooms.
How do the kids get out if there is a fire?
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 03-16-2010, 11:06 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I'm betting the large and airy windows
Old 03-17-2010, 07:00 AM   #5
DIY staff
Rewards Points: 7,174
Most(if not all)-brick yards will make up the block windows that you want----
They will mortar the blocks together and the put a steel band around the whole thing--
All you need to do is the actual install--Why learn the masons trade for one job--
They offer the service because masons do not like making up the blocks on site!
Good luck--Have fun--Mike--
timbo59 (05-04-2010)
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
Impact Windows & French Doors Matty16 Carpentry 6 06-22-2009 09:01 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Double-paned window glass replacement maximizer Building & Construction 5 08-18-2008 12:06 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 02:41 PM
