Using Felt Adhesive On Vertical Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-03-2011, 10:33 AM   #1
Using Felt Adhesive on Vertical Walls
I'm preparing to put felt or synthetic house wrap on a casita I'm building to use as an office. A contractor told me that if I use synthetic I should use the high strength spray adhesive
- six inches up from the bottom along the perimeter
- on all seams
- every so often while rolling it out.
I was thinking of going the extra mile and rolling contact cement on vs. the spray in the can. This seams to a common practice in the U.K. but not in america. Is the roof felt adhesive typically used for roofs the right adhesive for vertical walls too?
brainstewn is offline   Reply With Quote
Old 09-03-2011, 11:25 AM   #2
Rewards Points: 6,652
Only if you want to have a fire starter on your walls. This is one project, that I would not do. If you really want to do it, I would use a water based, low voc carpet glue.
Old 09-03-2011, 12:35 PM   #3
Thanks Greg excellent point!
Old 09-03-2011, 01:33 PM   #4
Before you do this, try the felt with the carpet glue on a test piece of material that is the walls of the casita to see how it holds up and what it will look like.
Old 09-03-2011, 11:44 PM   #5
Registered User
Rewards Points: 5,514
What are you covering--- OSB or plywood?
Where is it located?
What siding will be installed?
Gary
Need to rebuild outside steps and walls coming from basement doug123 Building & Construction 31 05-03-2010 07:45 AM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 05:59 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 08:17 AM
installing drywall to 10 ft vertical walls markt59 Building & Construction 6 01-16-2008 07:09 PM
Getting adhesive off walls dm62 Remodeling 5 04-14-2005 12:50 PM
