Using Concrete Filled Tires For Posts - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-15-2010, 09:44 PM   #1
using concrete filled tires for posts
I am building a workspace on uneven lava rock. I was thinking of filling tires with concrete to serve as the posts for the corners of the building and one in the middle with 4 x 4 attached to the concrete with metal brackets. Any ideas? Has anyone tried this? I think with some rebar reinforcement in the concrete and stacked two tires high for each post with a piece of plywood bolted to the tire underneath so that the concrete doesn't spill out it could work.
Any ideas about the structural integrity of this?
rescrewableE is offline   Reply With Quote
Old 04-15-2010, 09:56 PM   #2
Wouldn't it be easier to work with sonotubes -- it does not sound like the height will very much on these -- can you pin them into the lava somehow?
meboatermike is offline   Reply With Quote
Old 04-15-2010, 10:10 PM   #3
Yea, but sono tube costs $, while used tires are free and are clogging up the land fills. I could always stack more tires on top of each other to get more stability. I think pounding some rebar into the lava rock could work, although my goal is to build something that could be moved if the building inspector ever visits me. Most standard concrete posts for 4 x 4 aren't very tall, and tires would allow for a wider base.
Old 04-16-2010, 06:22 PM   #4
Rewards Points: 4,534
i like it even tho it'll take mucho moro cemento !
Tags
concrete , post , tire
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 05:53 PM
Soffits filled with Concrete Plaster donna.t Remodeling 6 02-08-2008 12:11 PM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
