Using Basement Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-23-2010, 08:39 PM   #1
using basement insulation
Hello all, very glad I found this site because I need a little help here.
I am redoing my bathroom, gutting down to the studs and rebuilding all around. I am putting in a new shower surround, Sterling Accord, and it will be against an exterior wall. When looking at faced insulations I noticed the faced basement insulation is much cheaper than the regular faced insulation. Could I use the basement insulation instead or is it too thin.
This is my first bathroom although I have worked with my uncles and father on theirs and am fairly certain my brother and I will be able to do this without killing each other. That's my disclaimer
northeast is offline   Reply With Quote
Old 07-23-2010, 09:03 PM   #2
I'm not sure what you mean by basement insulation
I have yet to see any insulation specific to a certain room
Where are you located ?
R13 is usually the min required....I use R19
Old 07-23-2010, 09:12 PM   #3
I live in MA, I never saw it either but there it was at homedepot for a 1/4 of the price. It was R13. Should I just look at the R value or is there a thickness I should be concerned with. I am sisterstudding all the way around.
Old 07-23-2010, 09:30 PM   #4
Usually when I see HD @ a lower prixce it means the roll is that much shorter
The $10 R13 rolls I have seen will not cover the same area as the bigger rolls
They may even be more $$ per sq ft
So 2x check the length of the roll & do the math 1st
Old 07-23-2010, 09:37 PM   #5
Thank you very much for the help!
Old 07-23-2010, 11:02 PM   #6
Registered User
Rewards Points: 5,216
You may want to check this before using a water sensitive insulation if on a basement concrete exterior wall:
http://www.buildingscience.com/docum...ent-insulation
Be safe, Gary
Basement insulation / vapor barrier questions deepstuff Building & Construction 16 02-09-2012 10:11 AM
Trying to understand insulation for my basement hyunelan2 General DIY Discussions 0 02-23-2010 08:06 AM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 05:44 PM
basement insulation advise needed bmartin5150 Building & Construction 1 04-27-2009 05:56 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
