Using Angles Or Joist Hangers To Support One Side Of A Door Header Ok? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-07-2012, 12:08 PM   #1
Using angles or joist hangers to support one side of a door header ok?
Hi-
I'm framing in a rough opening for a closet door in a non-loadbearing wall. The door is a pre-hung 2'-0" wide door. I don't have enough room to place a jack and king stud on both sides of the R.O. to support the header. Is it ok to support one side with Simpson hangers? Maybe toenail in the header and then put an angle support underneath?
Maybe there's another way to do this that is better?
Thank you for your advice.
Testarossa214 is offline   Reply With Quote
Old 01-07-2012, 12:11 PM   #2
Rewards Points: 13,764
Why not just move one of the 2 X 4 studs back 3" or each one 1-1/2"?
If you do not have the jack studs there how are you planing on attaching the outer edges of the casing.
Old 01-07-2012, 12:14 PM   #3
I would do this, but I don't have the wall space for it. I can put in a jack and king on one side, but not enough space for both and still fit the door.
Old 01-07-2012, 12:18 PM   #4
Is this a load bearing wall?
Hardway is offline   Reply With Quote
Old 01-07-2012, 12:19 PM   #5
For that small a door and in your case i would use 3" screws to sort of toe nail the header in place. Not nails.
Makes it easer if you predrill the header and insert the screws until there just below the end. That way your not trying to hold the screws and the header.
Testarossa214 (01-07-2012)
Old 01-07-2012, 12:40 PM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
Originally Posted by Testarossa214 View Post
Hi-
In this case you do not need a jack stud. Just toe nail in a 2/4 on the flat. The header is only to nail your casing on.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
Old 01-07-2012, 01:31 PM   #7
Use a 1x jack on both sides.
glkirk is offline   Reply With Quote
The Following 2 Users Say Thank You to glkirk For This Useful Post:
BigJim (01-08-2012), Testarossa214 (01-07-2012)
Old 01-07-2012, 08:38 PM   #8
In a little over my head
Rewards Points: 706
I like the 1x jack idea. Or, you could cut a rabbet, ledge, notch (what would it be called?) in the king stud to act as a jack.
(But I thought the joist hanger idea was pretty clever, too.)
ratherbefishing is offline   Reply With Quote
Old 01-08-2012, 07:29 AM   #9
Rewards Points: 2,238
"Testarossa214"
Use 1 X 4's as your cripples -
As "glkirk" suggests.
I don't remember where I stumbled onto that solution (long time ago) -
I think it might have been "Fine Home Building" magazine.
Apparently, someone had done some tests, related to using 1 X 4's as
cripple/jack, studs.
Properly, fastened to the "king", studs (nails/screws - glue) -
the structural performance is close enough to 2 X 4's - to be considered -
sufficient.
Especially, since the door is only 2 feet wide, in a non-load bearing wall.
rossfingal
By the way - we also used "angles/joist hangers" - "over-kill".
rossfingal is offline   Reply With Quote
Old 01-08-2012, 03:41 PM   #10
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,218
you can use 1x for the jacks, but why the hell is someone mentioning using 1x for the cripples.. that doesnt work. unless you simply mean the same thing as a jack.
where its not a bearing wall its fine. adding the 1x will simply make the door easier to trim by centering it up in between walls.. my only concern when doing this is making sure the king stud is dead straight and plumb, if not it can create problems if the rough opening is really tight
woodworkbykirk is online now   Reply With Quote
Old 01-08-2012, 04:06 PM   #11
Thank you all for the input. We ended up using 1x jack studs (and a 2x cripple above) and it worked well/looks good so far. We haven't put in the door yet, though, so wish us luck with that!
Old 01-08-2012, 05:17 PM   #12
I had a case where the rough openings were not the correct size for a standard pre-hung door. Here what did (non load bearing) it was dry walled. I used saws all and cut the nails out of the jack stud, lock side. Took the 2x4 and ripped about of an inch off the 2 in and replaced the jack stud with construction adhesive. Hung the doors with out any problems.
Old 01-08-2012, 05:18 PM   #13
Simpsons makes a dedicated header hanger that is structurally sound for instances where the wall is load bearing and no jack stud is possible. It was previewed in Fine Homebuilding and I've seen it in Home Depot.
emaxxman is offline   Reply With Quote
The Following User Says Thank You to emaxxman For This Useful Post:
Testarossa214 (01-08-2012)
Angled Rim Joist on 6X6 SUPPORT POST usc529 Building & Construction 1 01-06-2010 07:15 PM
one rotted deck joist to replace, need advice dougq Building & Construction 10 07-07-2009 02:18 PM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 01:07 PM
Garage ceiling joist support mountainmike Building & Construction 11 02-28-2009 07:16 PM
Wider Joist Hangers BigJimmy Building & Construction 1 10-28-2007 10:08 PM
