Use Of Blue Board For Planter Box Construction - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-10-2010, 07:45 AM   #1
Use of blue board for planter box construction
Hello everyone,
I want to construct a feature planter box (L6.0 x W0.9 x H1.5) as a feature in my backyard. I have been considering constructing it using a treated pine frame with 90x90 posts concreted into the ground (~300mm) braced with 90x45 cross members. Frame will be lined with blue board inside and out. Inside will be water proofed and outside will be rendred and painted. Will also have some form of drainage. I' m confident I can construct a sturdy frame but am not sure how the water proofed blueboard will perform once the planter box is filled with soil. Does anyone have any advice?
Kev P is offline   Reply With Quote
Old 11-10-2010, 08:45 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 628
Ayuh,... By Blue Board,..?? Do you mean the water Resistent drywall,..??
If so,... I doubt it'll last very long,... It's water Resistent, Not water Proof...
The Following User Says Thank You to Bondo For This Useful Post:
Kev P (11-11-2010)
Old 11-10-2010, 11:12 PM   #3
Rewards Points: 1,092
Does "blueboard" = XPS foam board? If so, it is water proof, but will decompose slowly if subjected to freeze/thaw cycles if water is up against it; ice crystals will chew at the surface as the water freezes, and that can penetrate the board, loosening the tiny beads all the way through. Then the board can get water-logged, even though the beads themselves don't have water IN them. This happens when blue foam is used in leaky roofs; I do not know how long it takes, but it happens. Curious: why are you blue boarding?
The Following User Says Thank You to jklingel For This Useful Post:
Kev P (11-11-2010)
Old 11-11-2010, 01:27 AM   #4
have you considered cement board?
1910NE is offline   Reply With Quote
The Following User Says Thank You to 1910NE For This Useful Post:
Kev P (11-11-2010)
Old 11-11-2010, 01:56 AM   #5
Or Alla board. Oh. Sorry. I thought he worked for the rail road. Never mind. j
Kev P (11-11-2010)
Old 11-11-2010, 04:25 AM   #6
Blue board is a compressed fibre cement product. It comes in sheets of various sizes and thicknesses. I'm thinking 7.5mm fixed to a frame at ~450mm centers
Old 11-11-2010, 10:02 AM   #7
joed's Avatar
Rewards Points: 12,008
Blue board appears tob e several different things.
Most comonn one is blue board drywall made to accept a veneer plaster finish.
It also appears to be a cementatious product used for cladding.
Ruud furnace issue on upgrade board and flame sensor rubberman HVAC 23 11-05-2014 01:36 PM
Installing 3/4" Engineered Hardwood over Particle board New_Floors Flooring 4 01-26-2011 10:23 PM
Basement construction project BlueBSH Building & Construction 10 11-30-2010 05:05 PM
Lennox G20 Series - Bad blower board - or is it more? inn8pwr HVAC 48 12-30-2009 05:13 PM
Connecting Ledger Board to Vertical Stud Alzipski Building & Construction 3 11-04-2009 03:53 PM
