Us / Brit Translation - A Little Help Here? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-10-2008, 09:53 AM   #1
Us / Brit translation - a little help here?
Hi folks,
I've run into a spot of bother writing a book about high tunnels (hoophouses) which will probably sell in the US too - and that's the names of some hardware products. We have a narrow perforated metal sheet that comes as a stiff roll, for cutting and nailing through if you want to strengthen a joint in a hurry - we call it "builders' band". If it's a heavier-duty galvanized flat plate, it's a "joining strip". What are the equivalent products over there in civilization?
hedgewizard is offline   Reply With Quote
Old 06-10-2008, 10:10 AM   #2
Rewards Points: 156
hmm...
Are you talking about this stuff:
http://www.homedepot.com/webapp/wcs/...ctId=100344678
Or this:
http://www.trim-tex.com/catalog/cbeads.htm
jayp is offline   Reply With Quote
Old 06-10-2008, 10:19 AM   #3
I believe the second item you have listed is a mending plate? Typically used on a roof truss.
jvc120er is offline   Reply With Quote
Old 06-10-2008, 10:27 AM   #4
Registered User
Termite's Avatar
What he's talking about is coil-strapping.
Simpson lists them under the product code CS and CMST. Widths vary from 1-1/4" to 3" and lengths range from 40' to 300' rolls.
http://www.strongtie.com/products/co...rs/cs-cmst.asp
Old 06-10-2008, 10:51 AM   #5
That's the stuff. Thanks very much!
Old 06-10-2008, 11:07 AM   #6
Wow! That stuff's expensive because it's only in trade packs. Any idea of something similar that comes in smaller packs? This is the Brit product;
http://www.screwfix.com/prods/38619/...lders-Band-10M
Old 06-10-2008, 02:39 PM   #7
Registered User
Termite's Avatar
The same company makes shorter straps that are basically the same thing.
How long do they need to be, and what width? I'm sure Simpson makes something, but you have a lot of choices.
www.strongtie.com
www.uspconnectors.com
