-   -   Us / Brit translation - a little help here? (http://www.diychatroom.com/f19/us-brit-translation-little-help-here-22060/)
hedgewizard 06-10-2008 08:53 AM
Hi folks,
I've run into a spot of bother writing a book about high tunnels (hoophouses) which will probably sell in the US too - and that's the names of some hardware products. We have a narrow perforated metal sheet that comes as a stiff roll, for cutting and nailing through if you want to strengthen a joint in a hurry - we call it "builders' band". If it's a heavier-duty galvanized flat plate, it's a "joining strip". What are the equivalent products over there in civilization?
jayp 06-10-2008 09:10 AM
hmm...
Are you talking about this stuff:
http://www.homedepot.com/webapp/wcs/...ctId=100344678
Or this:
http://www.trim-tex.com/catalog/cbeads.htm
jvc120er 06-10-2008 09:19 AM
I believe the second item you have listed is a mending plate? Typically used on a roof truss.
Termite 06-10-2008 09:27 AM
What he's talking about is coil-strapping.
Simpson lists them under the product code CS and CMST. Widths vary from 1-1/4" to 3" and lengths range from 40' to 300' rolls.
http://www.strongtie.com/products/co...rs/cs-cmst.asp
hedgewizard 06-10-2008 09:51 AM
That's the stuff. Thanks very much!
hedgewizard 06-10-2008 10:07 AM
Wow! That stuff's expensive because it's only in trade packs. Any idea of something similar that comes in smaller packs? This is the Brit product;
http://www.screwfix.com/prods/38619/...lders-Band-10M
Termite 06-10-2008 01:39 PM
The same company makes shorter straps that are basically the same thing.
How long do they need to be, and what width? I'm sure Simpson makes something, but you have a lot of choices.
www.strongtie.com
www.uspconnectors.com
