Upstairs Weight Limit - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-15-2010, 06:58 PM   #1
Upstairs weight limit
Hey guys, I have a 18 by 15 feet upstairs room and I have a pool table weighing around 700 ~ 1000lbs in the center of the room. Is this weight limit too much and will eventually cause the upstairs to collapse?
It has 4 legs. Each leg touching the wood floor is about 4 square inch.
Would it be a lot safer to make something that will allow the legs to rest on top of a 144 square inch metal/rubber?
osnits is offline   Reply With Quote
Old 10-16-2010, 06:16 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,384
Ayuh,... It depends entirely on the struture of the 2nd floor, 'n the support provided by the 1st floor...
To turn off the upstairs AC or not Big Dawg HVAC 18 08-11-2010 06:15 PM
Makeup Counter Weight Limit? greylockwood Carpentry 1 02-14-2010 07:31 PM
cream trim downstairs, white trim upstairs, advice for stairs? allyr Painting 1 09-26-2009 04:01 PM
Is there a weight limit in a Garden Window? rwith General DIY Discussions 5 05-15-2009 04:02 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
