Old 04-06-2010, 01:12 PM   #1
Upstairs/attic room insulation
We have a playroom upstairs. The ceiling and 2 walls are adjacent to the un conditioned attic. Should the walls be insulated to the same R-value as the ceiling? the walls have sprayed foam in 2x4 walls plus 1" rigid foam with foil on the attic side. ceiling has cellulose at 8" nominal. House is in the deep south. Maybe a dumb question but in this instance why wouldn't the walls need the same amount as the ceiling?
Jmcc64 is offline   Reply With Quote
Old 04-06-2010, 02:43 PM   #2
Remodeling Contractor
stack effect. hot air moves up, so more heat loss and gain is thru the ceiling. at the top and at the bottom of these knee walls you need to air seal the joist bays completely to avoid air wind washing the insulation and rendering it useless. Basically isolate the unconditioned attic completely from the conditioned space.
advice/Help on non-permitted bonus room? Orange_County General Discussion 43 06-11-2010 06:06 PM
Adding attic insulation pomelo Building & Construction 3 10-22-2009 06:19 PM
How hard to install insulation yourself? techprincesse Building & Construction 26 10-17-2009 10:57 AM
Old home insulation woes nowwhatnapster Building & Construction 15 11-03-2008 12:59 AM
Heat pump in non insulated nor heated room robdville HVAC 3 01-21-2008 03:51 PM
