Upgrading Old Kitchen Exhaust Fan - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-10-2010, 09:38 PM   #1
Upgrading old kitchen exhaust fan
I am looking to upgrade my kitchen wall exhaust fan. It is the older type with the pull chain. To operate it you release the chain which allows a spring loaded metal door to open on the outside of the house. When that happens, a button is released which turns on the fan. This is a common older design.
I would like to upgrade it to a higher flowing newer design, the type with the black box on the outside of the house with the damper on the bottom. I've seen the newer design fan "hacked" into the older drum with sheet metal screws and lots of caulk, but I was wondering if there is any proper way to retrofit a new fan into the old?
Lockeset is offline   Reply With Quote
Old 11-11-2010, 05:59 AM   #2
Trying to retrofit a new fan into an older housing often looks bad. Most fans come with the correct housing for thru the wall installation. Unfortunately, most of that type of fan are limited to low CFM and high noise fan motors. Squirrel cage type fans are usually more powerful and quieter, but need more space. They are found in the better range hoods or stand alone hoods, and require ducting to the outside.
Old 12-01-2010, 07:19 AM   #3
Agree with this opinion. I admire with it. :D
rightnwrong is offline   Reply With Quote
Old 12-01-2010, 09:19 AM   #4
Rewards Points: 5,336
How involved the transition will depend on the houses' exterior. The fan you have, while being a dated design, is a very effective unit to move air. As Bill said, melding the two units together can be a real ugly growth on the outside of the house. I don't think this is the," upgrade" you had in mind.
Post some pictures, interior and exterior, for suggestions as to possible transitions.
Ron
Old 02-22-2011, 12:40 PM   #5
there is an interesting article about that
http://www.rangehoodsstore.com/artic...haust-systems/
BronzeGenius is offline   Reply With Quote
Old 02-22-2011, 04:14 PM   #6
Rewards Points: 2,634
Here is another interesting article:
http://www.greenbuildingadvisor.com/...ir-range-hoods
SPS-1 is offline   Reply With Quote
Old Kitchen Brick Exhaust MichaelWayne_71 HVAC 5 12-03-2011 09:22 AM
kitchen range exhaust design ericadami HVAC 2 10-18-2010 12:40 PM
Bathroom exhaust vent in kitchen? dc4nomore HVAC 11 05-27-2009 12:06 AM
Kitchen Cooktop Downdraft Exhaust handy man88 Appliances 2 03-09-2009 07:30 PM
Recirculating Exhaust Fan in Gas Kitchen - Good/Bad? Crashless Remodeling 5 03-08-2008 09:18 AM
