Old 11-11-2012, 10:53 PM   #1
GBunny
Updating to Code
If I bought a house with a basement apartment that was built without a permit and I want to bring it up to code, what is the easiest way of doing this without ripping everything down and starting over?
GBunny is offline   Reply With Quote
Old 11-11-2012, 11:46 PM   #2
GBrackins's Avatar
Updating to Code
it could have been built to code without a permit. unfortunately to have it inspected and approved by the local authority you would certainly have to open up areas so compliance could be determined. It's also the only way for you to know if it was constructed correctly.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is online now   Reply With Quote
The Following 2 Users Say Thank You to GBrackins For This Useful Post:
reality (11-12-2012), vedika (02-22-2013)
Old 11-12-2012, 07:53 AM   #3
Updating to Code
Too many variables to give you an accurate answer. If the house is old, a permit might not have been required when the apartment was built. Have you checked to see if it's legal to rent even if it doesn't meet todays code? If so, it was probably grandfathered. Are you planning to rent the apartment to someone? Does your zoning allow two-family dwellings? I suggest you go to your local authority, tell them what you intend, and they will tell you what you need (or don't need) to do.
Old 11-12-2012, 10:21 AM   #4
Architect
Updating to Code
I am helping a client now address code compliance issues with a previously renovated and built-out basement.
Best I can tell at this time is that the building department just wants stamped and sealed permit drawings issued. (They just want their money).
jcarlilesiu is offline   Reply With Quote
Old 11-14-2012, 10:54 PM   #5
Updating to Code
You need to first determine what aspects of the finished basement apartment are in compliance and what is not. Common problems with a basement apartment that did not have the benefit of a Building Dept's plan review and inspections: ceiling height short, ceiling height beneath girders or ductwork short, lack of required light and ventilation, no opening for emergency escape and rescue, lack of smoke detectors, lack of carbon monoxide detector, failed to remediate dampness problems prior to build out, lack of required fire separation between dwelling units including any connecting doors, and failure to ventilate the heating appliance. That last one is a big one, if you had a heating appliance in a large unfinished basement it had a lot of combustion air available, close it up in a small utility room and you need to install vents for outside air. The above depends on your Building Code. Then you need to check local zoning; is an accessory dwelling unit permitted? good luck.
TheCamper is offline   Reply With Quote
Automatic Closet Lights Sav505 Electrical 52 12-28-2012 08:24 AM
Plumb island sink and AAV code for Ajax jhakkim Plumbing 2 02-14-2012 12:07 AM
Please Help - Error Code's 31, 32 and 42 on Carrier 58MVB 100 kolo HVAC 15 01-28-2012 11:13 PM
Lighting proximity to outdoor hot tub - Code Question jeffinpickering Electrical 0 09-12-2011 02:43 PM
Bryant Plus 90 Code 31 ~kirkland~ HVAC 1 03-08-2011 07:14 PM
