Updated Pics Of Stamped Concrete Curing - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-31-2010, 03:03 PM   #16
is the sealer generally added cost when getting concrete done, or always included in the estimate automatically?
amandalc04 is offline   Reply With Quote
Old 05-31-2010, 03:26 PM   #17
Concrete & Masonry
Rewards Points: 468
Originally Posted by jomama45 View Post
Amanda,
I have to admit that this whole situation puzzles me a bit.
What kind of contractor did you hire if you have all these questions, and are going to be sealing this yourself?
In all honesty, their work looks fine to me, but they seem to have really failed when it comes to communicating & educating the customer on a custom stamp job.
I personally would NEVER let a HO seal a job like this the first time. As a matter of fact, I won't accept full payment for a deco. concrete job until I've sealed it & the HO can literally see what they are getting.
Here's my actual advice now:
- Wet all the concrete down together, as this will be a fairly close representation of what the sealed concrete will look like.
- If acceptable when wet, seal the concrete with a sealer SPECIFICALLY designed for decorative concrete, specifically powdered, colored release agents. You will not likely find this good quality sealer at a "big box" store, but at a concrete or masonry supplier.
- I would suggest adding "Shark Grip" or the eqivalent to the sealer as well, especially if you use this area in the winter.
Good Luck.
jomama45 is online now   Reply With Quote
Old 05-31-2010, 03:32 PM   #18
are cracks normal during or not long after he curing phase? does this happen regardless if its sealed or not?
Old 06-01-2010, 05:29 AM   #19
Rewards Points: 4,440
oy vey, the saga continues,,, cracks ? WHAT CRACKS ? ? ? shouldn't be ANY cracks - - - AT ALL,,, no, NOT ' normal ' - sealed OR unsealed
might be a sawed OR formed contraction/expansion/isolation jnt but that's done while the conc's 'green '
stadry is online now   Reply With Quote
Old 06-01-2010, 08:51 PM   #20
Concrete & Masonry
Rewards Points: 468
As the senile old man above me said "WHAT CRACKS?"
More info is needed to answer this question. Where are the cracks?
Old 06-01-2010, 10:50 PM   #21
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
In the first post, last picture right near the bottom, right hand side just below the separation edging (don't know the proper term for it) line. I think that might be one of the cracks.
Stamped concrete kathy103 Landscaping & Lawn Care 10 10-27-2011 07:51 PM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 05:48 PM
"Haze" on stamped concrete PntrRookie Landscaping & Lawn Care 1 03-30-2006 08:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
