Unusual Use For A 2x4? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-13-2011, 08:41 PM   #1
ashkanr's Avatar
Unusual use for a 2x4?
My basement is unfinished. When I walk down the stairways to the basement, I can see bottom of the stairways to the second floor.
I noticed that they have carefully screwed a long piece of 2x4 to the bottom edges of the stairways (please see the pictures).
It will be a nightmare to drywall around it..
Do you have any idea why it is there?
Can I remove it?
ashkanr is offline   Reply With Quote
Old 09-13-2011, 09:15 PM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
maybe they did it to screw drywall to......
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 09-13-2011, 09:19 PM   #3
DIY staff
Rewards Points: 7,174
Am I seeing plywood stair treads?
AndyGump (09-13-2011)
Old 09-13-2011, 09:22 PM   #4
ashkanr's Avatar
Risers are osb, treads are 1" ply; is that bad?
Old 09-13-2011, 09:24 PM   #5
ashkanr's Avatar
But why just one? please see this pic:
Old 09-13-2011, 09:33 PM   #6
I wonder if those stairs were built off site and that is part of the original shipping packaging. Just guessing.
eastside is offline   Reply With Quote
Old 09-13-2011, 09:43 PM   #7
ashkanr's Avatar
That's a good guess; I remember they brought in the stair as a whole set. They were not build onsite.
But why carefully screw it with two screws at all the edges, if it was just a temporary support?
Old 09-14-2011, 05:45 AM   #8
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
I think it could be for drywall but it could have also been for shipping.
Big N8 is offline   Reply With Quote
Old 09-14-2011, 07:11 AM   #9
kwikfishron's Avatar
Rewards Points: 594
How wide are those stairs?
Everything I’m looking at is wrong and it has nothing to do with the 2x4 that has no reason to be there.
Those stairs would never pass here.
kwikfishron is offline   Reply With Quote
Old 09-14-2011, 09:17 AM   #10
ashkanr's Avatar
They're 3'3" wide.
Life is easy here! everything gets passed :D
Old 09-14-2011, 09:28 AM   #11
Rewards Points: 150
Considering how shoddy it's built, it could easily be for rack control. There's not a lot to keep the stairs from collapsing, I wouldn't remove it. This would not pass inspection here. Besides the methodology used, the width is far too narrow.
TrapperL is offline   Reply With Quote
The Following User Says Thank You to TrapperL For This Useful Post:
ashkanr (09-15-2011)
Old 09-14-2011, 10:18 AM   #12
ashkanr's Avatar
I'm from an area where everything was built on brick, mortar, concrete and steel. I do not have any experience with wooden stairs.
Do you mean they should have added more structural elements to the staircase?
I googled for stair constriction but they are mostly like what I have in the pictures. Obviously without that 2x4!
Old 09-14-2011, 10:28 AM   #13
Rewards Points: 594
I think you need to take a closer look.
Old 09-14-2011, 11:14 AM   #14
ashkanr's Avatar
You mean the well built stair treads are not slid in a routered groove? Is that the case?
Old 09-14-2011, 11:30 AM   #15
Rewards Points: 594
That groove is the old school way of doing it but the stringers, treads and risers were likely made oak not plywood and osb.
You need a center stringer supporting the treads. A plywood tread spanning 39 not safe. You must be able to feel movement when you walk the stairs.
The Following User Says Thank You to kwikfishron For This Useful Post:
Unusual Leak Issue Packerman Plumbing 16 02-17-2012 02:31 PM
I saw an unusual looking "tile" job on a shower... DangerMouse Plumbing 1 06-08-2011 04:18 PM
Need Help with Ridge Vent on Unusual Roof MSBOY Roofing/Siding 1 03-24-2010 09:46 PM
Electric Symbol for Unusual Outlets HooKooDooKu Electrical 4 02-24-2010 11:07 PM
Help with unusual liftable deck icu2 Building & Construction 19 08-19-2008 08:28 PM
