Untreated Lumber For Cantilever Joist For Balcony - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-10-2009, 11:32 AM   #1
untreated lumber for cantilever joist for balcony
I'm extending my bedroom and adding a 4' balcony on the outside of bedroom. I'm using 2x10x16 for the floor joist. The length of the extention is 12'6" leaving 3'6" for the balcony. I want to know if I can cantilever the the untreated wood for the balcony.
hebrewdiver is offline   Reply With Quote
Old 05-10-2009, 11:41 AM   #2
Rewards Points: 5,336
If the framing will be fully enclosed, so you can use regular framing lumber. What are the plans for the top surface to waterproof the structure.
This cantilever has been engineered?
Ron
Old 05-10-2009, 06:17 PM   #3
the bedroom extention will be fully enclosed but the balcony which is the cantilever section will not there fore the 2x10 that are making up the balcony area (4' long by 24' wide) will not. The top portion or flooring of the balcony can be pressure treat lumber(haven't installed it yet. If I enclose the untreated in some pressure treated plywood it will be ok. Or should I just bite the bullet and purchase pressure treated lumber for the floor joist that will be cantilevered?
Old 05-10-2009, 06:36 PM   #4
I'd go with PT, not that much more
Then you don't have to worry about a sealed deck & water run off
Old 05-10-2009, 07:37 PM   #5
Registered User
Rewards Points: 5,514
Different length cants for different locations. Some are 24" max. with 2x10, some are 36"max. Longer if engineered as Ron said.
Check with your local Building Department.
Page 3 and 4: http://www.bssconline.org/Homebuilde...e/Chapter4.pdf
Page 2, number 6: http://www.ci.apple-valley.mn.us/Ins...ck_handout.pdf
Everywhere is different. Be safe, G
Old 05-10-2009, 09:07 PM   #6
rwa
rwa's Avatar
Rewards Points: 43
I have to ask, is this a true cantilever (no support on the outer edge)? I'd also caution extending the floor joists the entire distance. Even PT lumber will need to be replaced at some point in time. I doubt that you would want to pull an entire floor just to replace a joist that is rotted at the exterior. Consider sistering off the floor joist whatever distance is necessary. Then, when the exterior does need to be replaced, in the worse scenerio, you could replace it by pulling the a portion of the ceiling below.
rwa is offline   Reply With Quote
Old 05-10-2009, 10:32 PM   #7
I still don't know how you're constructing this. Is there some sort of flooring? What is it made of? Is this going to be some sort of mini deck with wood on top or a waterproof material?
You wouldn't use a plywood to wrap regular framing material.
Ron
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
floor joist issue drtbk4ever Building & Construction 4 03-22-2009 10:20 AM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
Engineering help request: drilling holes in a deck joist, supported by a post Deck Building & Construction 14 05-31-2008 10:16 PM
Cutting/drilling hole in joist - How big? curls00 Carpentry 3 07-20-2007 09:56 PM
