Unsupported Top Plate - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-30-2011, 11:09 PM   #16
Ole Wood Worker
BigJim's Avatar
Rewards Points: 540
If you don't hang the door plumb it will drive you crazy every time you look at it, well I guess the difference in margin would too. I really don't see any other options than talking to your sheet rock fellow. Even at that it isn't an easy fix.
What type of flooring do you have on each side of that wall? What is on the other side of the wall? Which way is the widest margin at the top or bottom of the door way? The reason I am asking is I am trying to see if there is a way to move that bottom plate.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 07-31-2011, 12:03 AM   #17
Rewards Points: 508
Marble on one side and hardwood on the other. The hardwood hasn't been completely installed. The stud is actually leaning away from the door, so I have a wider margin at the top. I think we might be able to shim out the drywall, since the studs seem to be plumb a couple of studs over.
benjamincall is offline   Reply With Quote
Old 07-31-2011, 08:19 AM   #18
Ole Wood Worker
BigJim's Avatar
Rewards Points: 540
If that is the case with the studs being plumb that close I would give that a try. With the type of flooring you have on each side of the wall that may keep moving the bottom plate out.
Jim
Old 08-01-2011, 09:12 AM   #19
Rewards Points: 508
Jim,
I just came across a clever solution to the drywall problem: sistering studs to those that are out of plumb. This method won't help me with the door frame itself, but I won't have anything visibly asymmetrical once the drywall is up.
Old 08-01-2011, 09:34 AM   #20
Ole Wood Worker
BigJim's Avatar
Rewards Points: 540
That is a good idea, that should take care of that problem.
Jim
The Following User Says Thank You to BigJim For This Useful Post:
benjamincall (08-01-2011)
Old 08-01-2011, 09:45 AM   #21
Rewards Points: 508
Accidentally double posted. Thanks for the input!
HELP PLEASE replacing rotted sole, top and bottom plate dolson Remodeling 4 04-16-2010 06:54 PM
Replacing Section of Sole Plate RM575 Carpentry 3 03-28-2010 09:31 AM
Double sole plate how-to? HooKooDooKu Building & Construction 19 03-24-2010 01:43 AM
Getting Steel Plate Flush with Concrete Floor MrBill_DIY Flooring 7 11-29-2009 08:54 AM
OK to drill holes in top plate to run conduit? troll5501 Carpentry 4 05-11-2008 08:33 PM
