Unsafe Deck? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-27-2012, 12:26 PM   #1
Unsafe Deck?
I recently purchased a 6-year old house with an existing wooden deck attached to the back of the house. I noticed this past weekend that the rim joist is face nailed to the 6x6 posts. Would the addition of diagonal bracing and through-bolts where the rim joist is attached to the beam, provide enough support for the rim joist? I'm afraid this may be an expensive repair otherwise.
Mahogany is offline   Reply With Quote
Old 08-27-2012, 12:35 PM   #2
Rewards Points: 13,300
Post a picture.
Most likly what you suggested would work.
Old 08-27-2012, 01:44 PM   #3
Yes, pics would be helpful. I will try and post some tomorrow.
Old 08-27-2012, 05:34 PM   #4
Rewards Points: 454
Yes bolts will help.How wide is the deck coming off of the house.You might want to put a beam under it.
I dont understand but nobody on this site can answer a question with out a picture.I guess they cant picture it in thier head.
scottktmrider is offline   Reply With Quote
Old 08-27-2012, 05:42 PM   #5
Metal Roofing
Rewards Points: 600
I beleive Joe did answer it to the best of his ability...he asked for a pic to make sure he wasnt sending the OP in the wrong direction.
AndyWRS is offline   Reply With Quote
Old 08-27-2012, 07:14 PM   #6
robertcdf's Avatar
The beam should BEAR on top of the posts, if the beam is attached to the SIDE of the post then 2x4/2x6 PT should be added to the side of the post under the beam down to the footing on a standoff post base. Or temporarily support the beam and remove the post, then cut it to properly fit under the beam.
robertcdf is offline   Reply With Quote
The Following User Says Thank You to robertcdf For This Useful Post:
AndyGump (08-27-2012)
Old 08-27-2012, 08:38 PM   #7
Haverhill Trade 1965
There have been hundreds of decks built like this, (not saying it is right because it isn't). Most end up getting bolted, bracketed, replaced, etc. If you have any snow load it is much more serious.
Duckweather is offline   Reply With Quote
Old 08-27-2012, 09:20 PM   #8
GBrackins's Avatar
Rewards Points: 2,108
I've been designing buildings for over 30 years and I'd love to see a photo or two to make sure I understand the existing conditions before giving useful suggestions. Terminology is not always used properly by posters.
Maybe it's me, but I don't think I've ever seen a rim joist attached directly to a beam (per OP statement), I've seen joists attached to beams with either a drop beam or flushed framed beam. A rim joist is typically at the ends of floor joists running perpendicular to the joists. Now if this truly is a rim joist (single ply) that is connected to the posts (again, per OP) then I'd say there is either quite a few posts or it may not be of sufficient area for a bending member. A photo can answer these questions.
Now to the OP, if you check out the link below it will take you to the American Wood Council's "Prescriptive Residential Wood Deck Construction Guide." It provides the requirements for code compliant deck construction to meet the requirements of the 2009 International Residential Code (basis for most local and state building codes, your code may differ).
http://www.awc.org/publications/DCA/DCA6/DCA6-09.pdf
Figure 11 on page 8 indicates the proper attachment the rim joist to the floor joists. Figure 22 on page 14 indicates installation of lateral bracing for your deck.
If you post photos I'll be sure to check them out and provide appropriate feedback.
Hope this helps
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
Mahogany (08-28-2012)
Old 08-27-2012, 11:32 PM   #9
because every situation is unique. Supposing something that involves a structure can be life threatening.
Simple enough?
Tham
Tham is offline   Reply With Quote
Old 08-28-2012, 07:31 AM   #10
kwikfishron's Avatar
Rewards Points: 210
Exactly…I’ve seen many threads on this site where a question is asked then overzealous members offer solutions that end up to be completely wrong when twenty post later op finally posts a picture.
That exact situation was the basis for my signature line.
kwikfishron is online now   Reply With Quote
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
BigJim (08-28-2012), Fix'n it (08-28-2012)
Old 08-28-2012, 07:48 AM   #11
GBrackins's Avatar
you know it kwikfishron, you get one chance to get it right the first time thus my tag line ....
I never do a design without visiting the site and evaluating the existing conditions. This includes a new home on a vacant lot unless I have a complete topographic survey by a surveyor.
Gary
Old 08-28-2012, 12:54 PM   #12
Photos
I'm posting a couple of pics of the situation. Thanks for any advice you can offer.
Old 08-28-2012, 01:14 PM   #13
Newbie Bill
Rewards Points: 520
I'd like to see that rim joist doubled up and definitely bolt the rim joist to the post.
It lookes like the post extends through the decking for the railing posts. Is that correct? There should be a bit more support for the decking where it is cut around the posts.
Let's await the experts for more input.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 08-28-2012, 01:32 PM   #14
Originally Posted by drtbk4ever View Post
It lookes like the post extends through the decking for the railing posts. Is that correct? There should be a bit more support for the decking where it is cut around the posts...
Yes, the posts extend through the decking.
Old 08-28-2012, 03:03 PM   #15
GBrackins's Avatar
what are the dimensions of the deck, height about ground, size of joists, and spacing between posts?
Gary
Deck Staining Nightmare steven994 Painting 6 04-06-2014 10:10 PM
Is Natural Gas Firepit on a Wood or Composite Deck unsafe? Jakobud General DIY Discussions 4 03-29-2012 04:43 PM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 12:36 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
