Unorthodox Approach To Window Upgrade? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-11-2009, 10:10 PM   #1
unorthodox approach to window upgrade?
I have a little bay house and along the water front side the old porch was enclosed and "windows" installed. I put "windows" in quotes because what I have really is a single pane of glass framed in with something like 1"x1" wood. I have no need to open these windows so that's not a particular problem. THey do let in a lot of heat though. So would I be totally retarded to simply buy panes of low E glass and add a pane on the outside and perhaps the inside and make myself a 3 pane energy efficient window? I haven't priced out replacing this glass with real windows yet. I have about 8 of these and they are ~24"x36"
mhester1 is offline   Reply With Quote
Old 07-11-2009, 10:17 PM   #2
LowE is not a single pane of glass
LowE is a glass assembly with argon gas in between
Adding extra panes will help
But you can get fog/condensation in between the panes of glass
I'd install real windows or storms on the outside
Old 07-11-2009, 10:34 PM   #3
Actually it's the glass itself which is low E (different types of coatings are applied to the glass pane.) http://www.energysavers.gov/your_hom.../mytopic=13430
http://www.askthebuilder.com/B97_Low...Benefits.shtml
Argon (or krypton - even better) fillers help reduce heat flow and insulate and increases energy efficiency, though from what I've read not as much as the glass itself.
Trapping moisture in my scenario would be an issue like you mentioned. Not sure if there's a practical way to avoid that, so the cheap glass sandwich idea may not be a good one for that reason
Old 07-12-2009, 07:56 AM   #4
Rewards Points: 5,336
You would need to purchase a sealed unit of glass to be effective.
Ron
Old 07-12-2009, 11:19 AM   #5
As the previous poster mentioned, you need to get sealed panes or you will have problems with moisture buildup and fogging. You should be able to get units made exactly to the size of your opening in double or triple pane, low-e, argon, etc. Your local lumberyard or window supply company should be able to measure and give you a quote. You will just have to remove the stops and install the new panes.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 07-12-2009, 05:14 PM   #6
If the heat buildup is due to direct sun on unshaded windows then I think a piece of lowE glass would work. Simply leave a small air space for any moisture to migrate out. If you need actual thermal efficiency then new windows might be better. Another option if direct sun is a problem is to install a shade cloth on the outside. You can make a roll up assembly to get them out of the way when wanted. I did this on a house I once owned that had single pane windows facing west. It worked very well and made a huge difference on the heat load of the house in the evening. You can get different levels of blockage up to 80% I believe yet still see through the material.
Mike in Arkansas is offline   Reply With Quote
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 10:47 AM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 04:49 AM
Window jamb helpless handyman Carpentry 11 08-03-2006 12:45 PM
