Unnotched Stringer?? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-05-2012, 02:52 PM   #1
Unnotched stringer??
What is unnotched stringer stairs, how are they constructed? are they better than the other way?
Pattysue is offline   Reply With Quote
Old 11-05-2012, 03:59 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 180
They are usually an uncut 2X10 or 2X12 with cleats nailed or screwed to the side and treads mounted to the cleats. I think there is a thing called Ez Stairs or something like that made for this type situation but not sure. Sorry not much help with this type set up.
They are for sure not as good as the notched stringer stairs IMHO.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 11-05-2012, 04:06 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
just like Big Jim said ..... here's metal connectors made by Simpson Strong-Tie http://www.strongtie.com/products/connectors/LSC.asp
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 11-05-2012, 04:29 PM   #4
Rewards Points: 13,250
There's lots of other things you could also be talking about.
You can buy prefab stairways that do not use notched stringers for one,
Old 11-05-2012, 04:44 PM   #5
Framing Contractor
Rewards Points: 112
Absolutely not true Jim. There are many instances where unnotched (closed) stringers are almost always used. Basements and exterior are a few. This is done to save cost, but they still must be built securely. I have seen many attempts at notched steps that were done incorrectly or poorly as well. Notching the stringers weakens them and support needs to be added for longer ones. Closed stringers can support themselves over longer distances without added support.
sixeightten is offline   Reply With Quote
The Following User Says Thank You to sixeightten For This Useful Post:
mae-ling (11-06-2012)
Old 11-05-2012, 04:59 PM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 180
Let me rephrase that, I should have said, all the stairs I have built I never have built one in that fashion. To me the stairs would be dependent on the shear strength of the fasteners, I personally would not feel comfortable using that type of stairs with a very heavy load.
Closed stringers are a different story, they are notched or mortised and are not dependent on a cleat or metal bracket. In my other post I was referring to a cleat type stringer not a closed or full mortise stringer.
Jim
Old 11-05-2012, 09:46 PM   #7
Registered User
Rewards Points: 5,204
Fig. 28, 29 and Table 6: http://www.awc.org/Publications/DCA/DCA6/DCA6-09.pdf
Gary
Old 11-06-2012, 12:38 AM   #8
Rewards Points: 2,210
...To me the stairs would be dependent on the shear strength of the fasteners, I personally would not feel comfortable using that type of stairs with a very heavy load...
Have you ever used joist hangers for a flush Beam? Can be a greater load on a joist then on a stair step.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
BigJim (11-06-2012)
Deck stair stringer attachment drtbk4ever Building & Construction 8 10-04-2012 09:58 PM
Basement Stairway Stringer ladyhomeowner Carpentry 6 10-08-2011 11:09 PM
Need to build stairs--Is there a Stair Kit? Cocoxoxo Building & Construction 13 04-15-2010 09:52 PM
Staircase help please!!! sdba Carpentry 3 02-09-2010 01:58 PM
Screwed up stair stringer (picture in thread) iMisspell Building & Construction 9 11-13-2008 11:49 AM
