Unlevel Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-29-2013, 10:16 AM   #1
Rewards Points: 518
Unlevel foundation
When framing and dealing with variances in a slab, is the preferred method to build square walls on the ground and shim as necessary or to build and cut each stud to fit?
n0c7 is offline   Reply With Quote
Old 04-29-2013, 12:33 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
square and level always work best for me ....
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 04-29-2013, 12:39 PM   #3
Rewards Points: 518
Seems less frustrating too. I know there is a variance in one corner but I cannot easily determine how much it is out using a string line and line level since the distance is about 22' and the line sags and the line levels tend to give sporadic readings...
If I'm really out in one corner, say an inch, would it be better to shim at sill plate or top plate?
Old 04-29-2013, 12:56 PM   #4
GBrackins's Avatar
I'd shim at the sill plates, if you start off square and level and you build square and level then it should end up square and level ....
Gary
The Following 2 Users Say Thank You to GBrackins For This Useful Post:
concretemasonry (04-29-2013), n0c7 (05-07-2013)
Old 04-29-2013, 03:44 PM   #5
Rewards Points: 518
Does it affect strength and integrity if you start shimming quite a bit? Say 1-2" ?
Old 04-29-2013, 05:51 PM   #6
Rewards Points: 4,794
while not a framer, i'd work on the levelness of the conc foundation 1st,,, don't like the idea of big shims under a rim joist,,, but maybe that's just me calling back the conc sub to fix his work is also a good idea you could always get 25' of plastic tubing & make a water level - no sag in that 1
The Following User Says Thank You to stadry For This Useful Post:
n0c7 (05-07-2013)
Old 04-30-2013, 12:09 PM   #7
Old School
Willie T's Avatar
Just as a side note, you might want to drop by a ceiling tile supply house and buy a spool of "Zip Line" (looks like dental floss) Throw the heavy string back in the toolbox. This stuff hardly sags at all... AND they sell neat little rubber tipped clamps for each end.
And the results usually rendered by using Line Levels are an embarrassment. Even a water level will do a better job. Fact is, I have one, and use it quite a bit... especially around corners.
BTW, don't shim. Do you want the weight of your whole house depending upon shims that may crush or eventually rot out?
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
n0c7 (05-07-2013)
Old 05-05-2013, 11:47 PM   #8
Rewards Points: 518
This is a garage pad. Any recommendations for shims?
Old 05-06-2013, 07:23 AM   #9
Old School
Willie T's Avatar
Oh, that's different then. Shoot, just get the kid down the street to throw it together for you.
Say... you ever build in Bangladesh?
Willie T
MTN REMODEL LLC (05-07-2013)
Old 05-06-2013, 07:59 AM   #10
Roofmaster
Rewards Points: 2,210
You should have a perimeter curb around your garage that is level irrespective of the slab. This way you can wash the floor and hose out the garage, and your sill plates will not rot from wind blown rain, and washing the floor. If I were you I would form up a level perimeter curb with 3/4 inch plywood ripped level. Drill 1/2 inch holes in the slap and install some no. 4 rebar stub outs in the holes to lock the curb to the slab and install anchor bolts 4 ft. on center for your sole plate. Put skew-back on the top of the form on the inside to relieve the edge.
The Following User Says Thank You to jagans For This Useful Post:
n0c7 (05-07-2013)
Old 05-07-2013, 03:53 PM   #11
Rewards Points: 518
I spoke with the builder and they are going to rectify the issue by adding a curb.
Old 05-07-2013, 07:47 PM   #12
Roofmaster
You will be very happy they did, my friend. Good negotiating. Dont forget the skewback to relieve that sharp edge on the inside.
Old 05-07-2013, 09:51 PM   #13
Concrete & Masonry
Rewards Points: 636
I can't say I've ever seen a "skewback" used by a professional. It seems to replace an "edger", which most any concrete guy probably owns a dozen variations of, and has permanent calouses on their hands from using them. Is a "skewback" common in your locale??
jomama45 is offline   Reply With Quote
Old 05-31-2013, 04:20 PM   #14
Rewards Points: 518
So they poured a curb and it still has variances, much less than 1-2" I had before all over the place, but there is one spot that is 1/2" out for about 6 feet. They're not willing to do much about it.
Old 05-31-2013, 04:59 PM   #15
Oso954's Avatar
Rewards Points: 1,628
You can always set the framed wall and then fill that gap with non-shrink grout.
(and no, It is not tile grout)
Oso954 is online now   Reply With Quote
Increasing height of Steel Bulkhead Concrete Foundation ulrichfolkers Concrete, Stone & Masonry 5 06-18-2012 09:40 AM
Leveling skids for a shed on a unlevel concrete foundation will02 Building & Construction 7 01-16-2012 02:58 PM
Stone Foundation 'Temporary' Repair... Peter B. Building & Construction 17 12-16-2010 12:27 PM
Round House Foundation Feasibility Mswick Building & Construction 23 02-27-2010 08:34 AM
Foundation Repair Help rasilun Remodeling 1 10-15-2009 10:26 PM
