Old 07-07-2009, 02:56 PM   #1
Osiris's Avatar
Unlevel Concrete Slab for Shed
Hi,
We have a concrete slab in our back yard, about 15' x 10'. I assume it used to be level, but I am guessing there was some settling underneath and now it is not level. I talked to one contractor who said the whole thing would need to come out and a new slab poured, but I am skeptical. Is there any reason you can not pour something like self-leveling concrete on top of this to level out the slab?
Osiris is offline   Reply With Quote
Old 07-09-2009, 07:34 PM   #2
What you need to do honestly, is "cheat the trade". You need to call a few companies for "estimates", and each time they come ask that question, "Does the WHOLE thing gotta get replaced?" If you get plenty of yes's, then do it. If not, I would simply flash patch it with either hydraulic cement or see 10-60 or 10-61 Rapid mortar. The rapid mortar would be best b/c it allows you to do entire horizontal surfaces, and is used for strength gain.
http://www.buildingsystems.basf.com/...e.asp?prodID=1
Jamamros is offline   Reply With Quote
Old 07-09-2009, 09:20 PM   #3
It was a dark and stormy
Yoyizit's Avatar
You could roughen it first
http://www.csunitec.com/masonry-tools/scouring.html
and then put concrete on top, but I think the minimum thickness for a layer of concrete is 2".
You may want to embed wire screen in the new layer.
I have the same problem in my driveway but I need the edges of each slab to line up so I can't add thickness.
Old 07-09-2009, 09:24 PM   #4
Xtreme DIY'r
How far out of level?
I think I'd either use as is if not too bad or build a level wood floor over it
Or build the walls to adjust to the dip
My old shed is not level
I made the mistake of making the new 10x10 addition level
Old 07-10-2009, 08:42 AM   #5
gravity always wins
Dave asked the right question. How far out of level is it? If it isn't terribly far out, then compensate in the wall construction. Many shed/garage floors are poured with slope for drainage.
How to cut a hole in a concrete floor slab tomseeley General Discussion 7 06-10-2009 03:32 PM
Concrete slab unlevel... MT Stringer Building & Construction 14 10-26-2008 06:43 AM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 01:50 PM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 11:29 AM
