-   -   Unlevel Concrete Slab for Shed (http://www.diychatroom.com/f19/unlevel-concrete-slab-shed-48316/)
Osiris 07-07-2009 01:56 PM
Hi,
We have a concrete slab in our back yard, about 15' x 10'. I assume it used to be level, but I am guessing there was some settling underneath and now it is not level. I talked to one contractor who said the whole thing would need to come out and a new slab poured, but I am skeptical. Is there any reason you can not pour something like self-leveling concrete on top of this to level out the slab?
Jamamros 07-09-2009 06:34 PM
What you need to do honestly, is "cheat the trade". You need to call a few companies for "estimates", and each time they come ask that question, "Does the WHOLE thing gotta get replaced?" If you get plenty of yes's, then do it. If not, I would simply flash patch it with either hydraulic cement or see 10-60 or 10-61 Rapid mortar. The rapid mortar would be best b/c it allows you to do entire horizontal surfaces, and is used for strength gain.
http://www.buildingsystems.basf.com/...e.asp?prodID=1
Yoyizit 07-09-2009 08:20 PM
You could roughen it first
http://www.csunitec.com/masonry-tools/scouring.html
and then put concrete on top, but I think the minimum thickness for a layer of concrete is 2".
You may want to embed wire screen in the new layer.
I have the same problem in my driveway but I need the edges of each slab to line up so I can't add thickness.
Scuba_Dave 07-09-2009 08:24 PM
How far out of level?
I think I'd either use as is if not too bad or build a level wood floor over it
Or build the walls to adjust to the dip
My old shed is not level
I made the mistake of making the new 10x10 addition level :(
Maintenance 6 07-10-2009 07:42 AM
Dave asked the right question. How far out of level is it? If it isn't terribly far out, then compensate in the wall construction. Many shed/garage floors are poured with slope for drainage.
