Uneven Walls, What About Door Jam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-24-2010, 09:32 AM   #1
Rewards Points: 150
uneven walls, what about door jam
I have a foyer wall that leans a few inches inward due to settling of my garage. I'm getting ready to drywall...
I coud easily shim the wall to make it plum... but there is a single door, and I'm concerned that the side jam will look funny with a sort of trapezoidal shape following the shimmed wall (3.5" at bottom, to maybe 5"+ at top?)
Or just leave it all alone. Perhaps nobody will ever know... but I will think of it everytime I walk into the garage. just how i am ughh.
which is the lesser of two evils? what do you do when you come across an out of level wall?
johnnyboy is offline   Reply With Quote
Old 10-24-2010, 10:06 AM   #2
Framing Contractor
You should be more concerned about the wall leaning in and fixing that problem first before you try and hide it.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 10-24-2010, 10:56 AM   #3
Rewards Points: 150
who ever said it wasn't fixed? focus on the question at hand. thanks.
Old 10-24-2010, 11:35 AM   #4
Framing Contractor
How is it fixed if the wall is still not plumb by almost 2"?
You either make the wall plumb by moving it in or out at top or bottom, or add new studs along side the existing studs plumb. Nail a stud at each end plumb and then string a line top and bottom and sister studs along side every stud on the wall until they hit the lines top and bottom.
Joe Carola
Old 10-24-2010, 04:18 PM   #5
jlhaslip's Avatar
Rewards Points: 2,206
... and then re-hang the door...
Good call Joe. I have also cut long tapers to fix stuff like this. You would need to do inside and outside to 'fix' it correctly.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
Basement Walls - Which Paint?Drylok? HandyFrank Building & Construction 3 10-17-2010 12:07 PM
Caulk on walls, priming, trouble with lines, and more! mrsjande Painting 7 09-10-2009 09:29 AM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 08:17 AM
Moisture on walls chrisr Building & Construction 1 01-20-2008 09:37 AM
