Old 10-19-2009, 12:59 PM   #1
Default Uneven grout color
We had the tile replaced in our shower. Everything was removed (tile, wallboard, etc.), and new tile was installed. Some small areas of the grout are darker than others. About 90 percent of the grout is the desired beige color. A number of small sections are a brown color, as if the grout didn't dry. The contractor used polyblend sanded grout. The darker coloring is especially bad in the corners of the two niches for holding soap and shampoo bottles. See the attached pictures.
What caused the problem?
How can we get rid of the dark sections of grout?
In the future, how can this coloring problem be prevented?
uneven-grout-color-img_3045.jpg   uneven-grout-color-img_3061.jpg   uneven-grout-color-img_3050.jpg   uneven-grout-color-img_3053.jpg
homeownertexas is offline   Reply With Quote
Old 10-19-2009, 05:51 PM   #2
Residential Remodeler
How long ago was the shower grouted?
CookeCarpentry is offline   Reply With Quote
Old 10-19-2009, 08:57 PM   #3
The grout was applied Monday, October 12. The contractor let it sit 48 hours, and was going to seal it October 15, but he didn't because of the color problem. So the grout has been untouched since it was applied a week ago.
Old 10-20-2009, 09:06 AM   #4
Given that it has had time to cure, it sounds like the colorant had lumps in it and/or did not get blended properly into the mortar. You may have to remove it and start over. Sorry.
sdsester is offline   Reply With Quote
More On This Topic
Enhance your next mosaic tile project with dyed grout to show off your artwork. By customizing the grout color, your mosaic tile project looks exactly the way you want it to when it is complete. Read More »
Using Mosaic Tile Grout
Using Mosaic Tile Grout by Expert Village
You'll find grout at any hardware store. You'll find sanded and non-sanded grout. Sanded grout is good for almost every mosaic project. The theory is, as long as your grout joints are more than a quarter inch apart, then you'll want to use sanded grout... Read More »
Hi this is Jon and in this clip we'll be grouting. If we take a look at the base of our door on the inside we have a nicely laid tile that's grouted, however when we did install the door we had to chip away some of the grout so that our new door would... Read More »
So now you've got a bunch of broken tiles, what do you do next? It's time to start positioning them onto your sub straight. There are a couple of things to think about when you're positioning tiles. If you have a shape or a central feature that you're... Read More »
A glaze, which provides color and texture, is basically liquid glass the manufacturer sprays, pours, drops or silk screens onto the tile. They then bake or kiln fire the tiles to harden the glaze. Most ceramic tile is glazed, and with so many variations... Read More »
Removing color from colored grout jeffmn Flooring 2 10-16-2009 11:10 PM
Help! New grout color uneven enchilila Flooring 14 07-25-2008 08:33 PM
Grout color rubs off lmlark Flooring 10 07-24-2008 12:15 PM
another grout color change question tryinitmyself Flooring 1 02-22-2008 08:50 PM
Unmatched Grout Color flyultralite Building & Construction 0 02-12-2008 01:20 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
