Uneven Floor Joist - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-19-2012, 07:49 PM   #16
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
hopefully, my husband and father can move forward without any more major problems.
You mean, BOTH your husband and your father, right? They are two separate people I presume?
Sorry teach, I just had to comment on that.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 06-19-2012, 08:54 PM   #17
Civil Engineer
Rewards Points: 4,948
It might be a very good idea to invest in a level, they can be obtained for under $300, and once you learn how to use one, there will be absolutely no question about which piece of the framing is too high/low. Personally I use a rotating laser level, which sends out a rotating light beam at a constant elevation, so it is very quick and easy to determine the exact elevation of any point. You are going to need to do this throughout the construction process, for setting the foundation, setting the sills, setting the joists, major beams, second floor etc. My laser can also be used to determine if a structural element is plumb, although most of the time I use a carpenter's level for that. Can also be done with a plumb bob. Regardless of what you use, you absolutely need tools to level and plumb your framing and walls, and you need to know how to use them. Bad things happen when the structure is not level and plumb.
Daniel Holzman is online now   Reply With Quote
my uneven floors are making my doors uneven fundaqueens Windows and Doors 4 05-04-2011 09:00 PM
Uneven Floor Problem JasonP2010 Flooring 1 06-09-2010 03:10 AM
Uneven ceiling dudepigeon Carpentry 3 07-08-2009 12:13 PM
Wet basement, uneven floor - what's the best flooring? pepsigirl Flooring 1 05-16-2009 07:36 PM
fixing baseboard on uneven floors? boodog Flooring 5 10-08-2007 03:20 PM
