Uneven Floor Joist - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-15-2012, 05:43 PM   #1
Uneven floor joist
I think we have bit off more than we can chew. We are building our own home. The floor joists are not level. It seems to me (I am not a contractor) that the foundation we poured must not be completely level. So how do we get the floor joists in the middle to come down. If we remove the face plate then there won't be a plate on the foundation. If we don't the joists towards the middle with be higher than the ones on the ends. Any suggestions?
superteach11 is offline   Reply With Quote
Old 06-15-2012, 06:21 PM   #2
Haverhill Trade 1965
Without more info, if the foundation is the problem, there are companies that can cut concrete. It isn't cheap, but may cost less than other fixes. Mostly you would have to jack up the floor enough to take the weight off so the saw does not bind. This is assuming you don't have the walls up yet.
Duckweather is offline   Reply With Quote
The Following User Says Thank You to Duckweather For This Useful Post:
superteach11 (06-15-2012)
Old 06-15-2012, 06:23 PM   #3
We don't have walls up yet. There isn't any other way to get it level like cutting out the plate?
Old 06-15-2012, 06:32 PM   #4
Cutting / removing plates, (sills, there should be two) not really a right way. Maybe if there is only one or two high joists you could notch into one sill with a sawzall then rip the bottom of the rim joist. If you only have one sill it isn't a good idea.
Old 06-15-2012, 06:34 PM   #5
GBrackins's Avatar
Rewards Points: 2,108
do you have any photos? when you say middle do you mean the joists between the two side foundation walls or do you mean the middle between the front & rear foundation walls?
what type of foundation? full basement, crawl space?
do you have a center beam? is it set at the correct elevation (top of beam level with top of sill plate?
again, photos sure help ....
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 06-15-2012, 06:35 PM   #6
Post pics and give us some dimensions to work with! Bet you'll get a ton of suggestions if you provide plenty of good information.
Evstarr is offline   Reply With Quote
The Following User Says Thank You to Evstarr For This Useful Post:
Old 06-15-2012, 06:46 PM   #7
Thanks will take a picture and will let you know.
Old 06-15-2012, 07:48 PM   #8
Bill Kearney
Rewards Points: 1,174
Fix the foundation. Do not leave anything out. Do not cut and end up with undersized joists. If anything, go a larger size on all the others and only adjust the ones at the higher points. But without a better explanation and some pictures it's impossible to say what to do.
wkearney99 is offline   Reply With Quote
The Following User Says Thank You to wkearney99 For This Useful Post:
Old 06-15-2012, 10:16 PM   #9
I mean the middle between the front and read foundation walls. It is on a crawl space. I do have a center beam, but I will have to check to see if the beam is level with the sill plate. I will get pictures when we go back tomorrow. Thanks for the time to answer.
Old 06-15-2012, 10:24 PM   #10
GBrackins's Avatar
if they are higher between the front & rear foundation walls, and you have a center beam it's very possible the beam was set too high. I'm curious to find out what you find ....
hope this helps
Gary
The Following User Says Thank You to GBrackins For This Useful Post:
Old 06-16-2012, 11:34 AM   #11
AHH, SPANS!!!
Rewards Points: 1,166
a quick and easy way to adjust already built in place floor joists to fit an uneven foundation. use a scrap 2x4 block and nail down flat at the edges of the room. nail a nail that sticks out of block to each block and use a strong string line strung to the nails and pull it tight from block to block. the string should be 1 1/2" off of the floor joists so use another 2x4 block and use it for a guide along each floor joist to show how in line the joists are with the ends of the room. if a joist is to high then to cut it free, use a sawz all and cut free the joist and notch out the underside to allow it to rest down into position at the correct height. if joist is to low then use sawz all and then shim under joist to raise it up to the correct height.
hand drive is offline   Reply With Quote
Old 06-16-2012, 01:34 PM   #12
Rewards Points: 1,910
I assume that you are not actually building this since, if you were, you would have to already know how level the foundation was before the 1st plate went down and you would already know the beam height.
So my question is why are you not asking the contractor how he is going to fix this? I would seriously begin looking for a new contractor. If yours is having difficulty getting the floor system down level then I can only imagine how bad the rest will come out.
Old 06-16-2012, 02:11 PM   #13
Bill Kearney
Originally Posted by jogr View Post
I assume that you are not actually building this since...
Because you didn't read the part about "we are building our own home"?
I'd be shaking my head at any outcome that would lead to even needing to ask the original questions. So, yeah, you have to wonder just where this is heading. Permits involved? Inspections? No? Ugh.
Old 06-16-2012, 02:24 PM   #14
DIY staff
Rewards Points: 7,174
I've dealt with some really out of whack foundations---adjusting the sill plates was always the answer--who has the luxury of stopping all work while the foundation top is ground down?
Proper framing--sill sealers and grout should be the answer--
superteach11 (06-16-2012)
Old 06-19-2012, 07:30 PM   #15
Thanks for all the help. We had my brother-in-law come down and look at it. I hated to make him drive, but having a live person come look seemed like a better idea than just posting pictures. It was the foundation was a little high towards the middle. They cut down the foundation and the floor is laid. Now, hopefully, my husband and father can move forward without any more major problems.
The Following User Says Thank You to superteach11 For This Useful Post:
oh'mike (06-19-2012)
my uneven floors are making my doors uneven fundaqueens Windows and Doors 4 05-04-2011 09:00 PM
Uneven Floor Problem JasonP2010 Flooring 1 06-09-2010 03:10 AM
Uneven ceiling dudepigeon Carpentry 3 07-08-2009 12:13 PM
Wet basement, uneven floor - what's the best flooring? pepsigirl Flooring 1 05-16-2009 07:36 PM
fixing baseboard on uneven floors? boodog Flooring 5 10-08-2007 03:20 PM
