Uneven Boards - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-28-2011, 02:43 PM   #1
wraiththe's Avatar
Rewards Points: 91
uneven boards
Hi,
I am rebuilding a shower with 1/2 wedi board, but the rest of the dry wall boards in the rooms are 5/8". No one in town here seems to sell 1/8" furring strips. I am not sure of any materials I can find to put between the studs and the wedi board to make the transition smooth. Any Ideas?
Kevin
PS. Lowes and Home Depot only carry 1/4" furring strips.
wraiththe is offline   Reply With Quote
Old 11-28-2011, 02:52 PM   #2
Missouri Bound's Avatar
1/8" luan or masonite...pegboard material.
Old 11-28-2011, 08:29 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 996
yup, hardboard will work.. if you have a table saw, just get a couple straight 2x4's and make furring strips thats how i do it on renovation situations where old walls arent flat and need to be furred which will create a flat finished surface
woodworkbykirk is offline   Reply With Quote
Old 11-29-2011, 11:05 AM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Drywall shim strips.
Old 12-01-2011, 05:53 PM   #5
wraiththe's Avatar
Rewards Points: 91
Thanks bud, but no one seems to offer them in 1/8" strips in Charlotte. Looks like I may have a relative bringing a table saw, so that is one less expense. However... I did noticed Lowes has wooden lattice made of... are you ready for it.... 1/8" by 1.5" strips of pressure treated wood. If disassembled a 4x8 would provide me with more than I need.
Old 12-01-2011, 05:58 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Here Home Depot, Lowe's, Menards, Builder's Warehouse all carry the shims. Are you looking in the right place? The shims are found with the drywall supplies such as corner beads and joint compound. They are about 1/8" X 1-1/2" X 36" and nothing more than thick cardboard strips.
XXX
Old 12-01-2011, 08:15 PM   #7
wraiththe's Avatar
Rewards Points: 91
Yes, I have checked. Gone to both Home Depot and Lowes on multiple occassions and asked. More than one store too. I have even called all the lumber yards I could find to no avail. The only shims I could find were 1/4 sloping down to zip and about a foot long by 1 1/2" checked the whole lumber and sheetrock areas. even a section that says furring strips, but the thinnest they have is probablby .5" No one has ever been asked for it there either.
Old 12-01-2011, 09:15 PM   #8
You have't got a table saw?
Old 12-02-2011, 12:49 AM   #9
wraiththe's Avatar
Rewards Points: 91
I wish. We live in a condo, not much room here. I have a relative bringing one tomorrow. either I will buy the lattice, or we will use it to rip some furring strips.
Old 12-02-2011, 08:45 AM   #10
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Are the studs exposed right now? Sister studs off- set 1/8"?
titanoman is offline   Reply With Quote
Old 12-02-2011, 08:55 AM   #11
Rewards Points: 6,652
Why not have the relative before they bring the saw, cut a bunch of strips off of a 2x4, so that way it speeds up the process. Then, as needed, if they have to use the saw, they are not running it for a couple of hours, disturbing everyone. And actually you can still get furring strips, you have to find a real lumber yard. Charlotte is full of old history, and I bet if you look for a Architectural warehouse, they will have bundles of them.
Old 12-02-2011, 11:10 AM   #12
wraiththe's Avatar
Rewards Points: 91
I will give it another shot, but I have called at least 5 lumber yards. None have them and none are willing to cut them for me.
Old 12-02-2011, 11:27 AM   #13
You can find them, you just need to look harder, or do as I stated before, have the owner of the table saw, pre-cut the furring strips. They can leave the whole board intact, with just a small bit at the ends, holding the strips. You then just take a handsaw and cut that bit, to break off the strips. That way, you do not have to bundle them with tape to transport.
Old 12-02-2011, 11:49 AM   #14
wraiththe's Avatar
Rewards Points: 91
I found the drywall shims. They are mail order only. The people in the stores have never heard of them. There are no more lumber yards to try and no architechtural supply stores within 60 miles.
Old 12-02-2011, 11:53 AM   #15
Disabled wood vet
titanoman's Avatar
What am I missing? How come you can't just screw some sister studs to the existing studs except hold hold them out the 1/8" that you need?
Deck Boards and Deck Size Earnie Building & Construction 6 09-12-2011 09:38 PM
Original Fascia boards need to be replaced brickhaus Roofing/Siding 3 08-25-2010 11:10 AM
Gate post ledger boards Klawman Building & Construction 5 04-14-2010 02:22 AM
floating floor boards over uneven tiles joey44 Flooring 8 01-05-2009 09:58 PM
hardwood flooring boards matjone Flooring 4 02-01-2008 06:35 PM
