Old 03-02-2013, 01:20 PM   #1
understanding codes
I m wanting to install exterior patio doors at the bottom of the stairs that come down from a loft style bedroom, is there any building codes that allow or deny this.
russells is offline   Reply With Quote
Old 03-02-2013, 02:50 PM   #2
understanding codes
Got a picture?
I'm sure someone will have the exact distance but there has to be a landing, you can not be still sanding on the stair when opening the door.
Old 03-02-2013, 02:57 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
understanding codes
it depends. how is it a slider or a swinging door. how much floor space between the stair and the door
woodworkbykirk is offline   Reply With Quote
Old 03-02-2013, 04:14 PM   #4
Civil Engineer
understanding codes
Building codes plus interpretation are local. You need to discuss the project with your local building inspector.
Old 03-02-2013, 09:23 PM   #5
GBrackins's Avatar
understanding codes
typically you are required to have a landing at the bottom of a flight of stairs. depending on your local code the landing is required to be at least 36-inches (between the stairs and exterior wall.
A quick call to your local building department will provide the actual requirements you need.
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 03-02-2013, 10:58 PM   #6
Moderator
understanding codes
Pick the State to find which Building Code you are under, may include local amendment; http://www.reedconstructiondata.com/building-codes/
All but a small handful are under this prescriptive code of IBC or an earlier year: http://publicecodes.cyberregs.com/ic..._10_par144.htm
As stated; check locally.
Gary
PS. Welcome to the forums!
Clothes taking longer to dry?
Deck Building Codes ashleyripka Building & Construction 18 12-02-2012 08:13 PM
Do Indoor Dryer Vents meet safety codes in Alberta (Canada) maneatingcow HVAC 4 09-23-2011 11:30 AM
Zinsser bin lot codes / date codes Crystal2 Painting 4 06-21-2011 06:50 AM
Carrier Weathermaker SXi Codes 41 and 44 Knight78 HVAC 5 11-12-2010 07:18 AM
Where to find building codes? nimblemotors General Discussion 5 06-27-2008 08:15 AM
