-   -   understanding codes (http://www.diychatroom.com/f19/understanding-codes-173395/)
russells 03-02-2013 01:20 PM
understanding codes
I m wanting to install exterior patio doors at the bottom of the stairs that come down from a loft style bedroom, is there any building codes that allow or deny this.
joecaption 03-02-2013 02:50 PM
Got a picture?
I'm sure someone will have the exact distance but there has to be a landing, you can not be still sanding on the stair when opening the door.
woodworkbykirk 03-02-2013 02:57 PM
it depends. how is it a slider or a swinging door. how much floor space between the stair and the door
Daniel Holzman 03-02-2013 04:14 PM
Building codes plus interpretation are local. You need to discuss the project with your local building inspector.
GBrackins 03-02-2013 09:23 PM
typically you are required to have a landing at the bottom of a flight of stairs. depending on your local code the landing is required to be at least 36-inches (between the stairs and exterior wall.
A quick call to your local building department will provide the actual requirements you need.
Good luck!
Gary in WA 03-02-2013 10:58 PM
Pick the State to find which Building Code you are under, may include local amendment; http://www.reedconstructiondata.com/building-codes/
All but a small handful are under this prescriptive code of IBC or an earlier year: http://publicecodes.cyberregs.com/ic..._10_par144.htm
As stated; check locally.
Gary
PS. Welcome to the forums!
