Underslab Insulation For Radiant Heat - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-13-2011, 02:40 PM   #1
Underslab insulation for Radiant Heat
Hello;
I recently came across enough 2" Polyisio rigid insulation to completely cover underneath my concrete slab in a cottage I am building. My question is. If I cover it on both sides with 6ml. poly will this be sufficient to keep moisture out of my insulation under my cement slab? This insul. has a paper backing and is designed for under roofs.
Cheers
Borts25
Borts25 is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
edge insulation on slab for radiant heat crankcase General DIY Discussions 5 10-06-2010 12:49 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 09:34 PM
Cracked Heat Exchanger SusanB. HVAC 12 10-14-2008 04:57 PM
