Underpinning A Rubble Stone Foundation Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-16-2011, 09:12 PM   #1
Knucklez's Avatar
Rewards Points: 942
underpinning a rubble stone foundation wall
just doing some preliminary research and wanted to know if it is possible to lower a residential basement floor 3'. yes of course.. but what if the basement wall is rubble stone with no footer (common for 100+ yr old homes). the stone wall goes down the required 4', but there it stops on the soil. i think the soil down there is soil/clay but not sure. the plan would be to go down a further 3'.
underpinning to be completed from the inside.
is it still possible to underpin, or would a SE just say no?
maybe "yes" but SE would change the design to have only 18" wide pours with minimum 3 day drying time before the next pour which is 8' edge to edge distance away. ? quite a bit more labour & long delays this way but it could be done .. if approved.
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
adding rock panels to old stone wall adzling Building & Construction 0 09-27-2010 11:41 AM
Foundation or Load Bearing Wall Issue? sheribaby Building & Construction 3 04-14-2010 05:07 PM
General costs for stone foundation repairs?? Jeff DIY Building & Construction 3 01-28-2010 08:07 AM
Water in crawlspace, dug out too close to foundation, How to fix? Build a wall? twilightcall Building & Construction 6 05-18-2009 09:16 AM
How important is plastic vapor barrier on foundation wall? slatergrl Remodeling 5 02-18-2008 12:49 PM
