Underpinning Outer Garage Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-10-2008, 09:21 PM   #1
Underpinning Outer Garage Wall (Please Help)
Hello Guyz,
I am buying a house and I really need some info on underpinning outer garage wall. The 1.5 car garage was added seperately to the house.
The garage is attached to the right side of the house. There is a breeze way between the garage and the house to get into the house from garage.
It was recommended by the inspector to do the underpinning to outer wall of the garage from outside. This wall is made of blocks but it does have a concerete block base underneath. The garage is kind of detaching itself from the house and eventually will break of the roof shingles as well.
Inspector said I would need to dig about 6 feet a part and about 4 feet deep and pour concerete etc...
This job does not need to be done urgently but I just need to know the step required.
I would really appreciate and feel better if someone can shed some light as to what steps are need to do this myself and the material needed.
Thank you in advance.
sport2002 is offline   Reply With Quote
Old 04-11-2008, 07:13 AM   #2
so-elitecrete
Rewards Points: 150
underpinning's a term for,,,
digging a hole under the fnd & placing concrete usually,,, we did this often when installing sub-floor perimeter water management systems,,, you'll want to spread the load equally at either side of the fnd.
depth of anchor depends largely on soil strengths,,, if those don't work, you may need soil cements or earth anchors.
so-elitecrete is offline   Reply With Quote
Old 04-11-2008, 07:56 AM   #3
so-elitecrete..thanks a lot for your reply...
Do you mean that I will need to dig from both sides of the wall. Outerside of the wall is just sand but inside is concerete floor, that might be a little hard. Plus, can I just dig and find the base of the block foundation and just pour the concerte...and filll up the hole with sand afterwards.
I will continue to do this with 5 feet gap between each whole I dig to cover 20 feet garage. I would obviously wont dig it all at once but do one hole at a time each week. I will probably have to dig 4 holes to cover the 20 feet long garage.
Please correct me if I am wrong.
Old 04-11-2008, 09:20 AM   #4
so-elitecrete
Rewards Points: 150
if it were my garage,,,
i'd be diggin' from the sandy side 'cause we're all lazy, too the rest sounds right to me.
you're welcome !
Old 04-11-2008, 11:24 AM   #5
thanks a lot...
that makes me feel much better...I am probably going to buy the house since there is nothing wrong with the house foundation itslef it was just the garage.
At least I know What is needed to be done to fix the garage.
Thanks again
Frost Build Up On Interior Garage Wall richw Building & Construction 8 01-06-2008 09:47 AM
Garage wall construction question Bjonas Building & Construction 4 01-01-2008 04:18 PM
Replacing Wall in Garage viking1974 Building & Construction 3 08-10-2007 10:23 PM
Help Repair Garage Wall - Advice RandomJustice Building & Construction 8 07-28-2007 10:02 PM
