Undereave Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-30-2013, 08:33 AM   #1
Undereave question
I noticed that my soffits do not have any perforations in them. Can I assume that these are not vented soffits?
miguel24932 is offline   Reply With Quote
Old 03-30-2013, 08:39 AM   #2
Rewards Points: 13,694
No holes, no vents.
Got a picture?
Old 03-30-2013, 11:03 AM   #3
Originally Posted by joecaption View Post
No holes, no vents.
Got a picture?
We have gable vents.
Old 03-30-2013, 11:30 AM   #4
Roofmaster
Rewards Points: 2,210
"We have gable vents" Nice Picture.
Before you ask, yes you need insulation baffles if you install continuous soffit venting. Before you ask, yes you should be able to do it from the under eaves. Yes, you can retrofit a continuous ridge vent. Yes, you should close off the gable end vents if you do add continuous soffit and ridge venting.
Do you need to do all this? Probably not. Maybe you have a poorly sealed attic entrance, an exhaust fan blowing into the attic, heat loss at lighting fixtures, high internal humidity from burning gas, etc. etc. etc.
We have to assume you are asking about your soffits for a reason, I guess.
The Following User Says Thank You to jagans For This Useful Post:
GBrackins (03-30-2013)
Old 03-30-2013, 04:02 PM   #5
GBrackins's Avatar
Rewards Points: 2,108
and as a reminder, photos go a long way in getting specific answers
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
kwikfishron (03-30-2013)
Old 03-30-2013, 04:06 PM   #6
If there's no soffit vents then any other venting is all but usless.
Try sucking on a straw with your finger over the end of it? Works the same way.
Old 03-30-2013, 08:51 PM   #7
Dave Sal's Avatar
Rewards Points: 664
When I first bought my house, which was new construction, I didn't know much about attic venting let alone most DIY stuff. The builder never bothered to install any soffit vents at all. On the lower level roof (tri-level home) one of the cutouts for a static vent was simply covered with a piece of asphalt shingle laid upside down over the hole. I ended up learning about attic venting by reading home improvement books and bought about 30 small soffit vents and installed them equally between the upper and lower levels, and also doubled up on the attic insulation, which was so minimal that I reduced my heating bill by almost half the following year. Within the last two years I enlarged all of the soffit vent cutouts and installed large vents. Now the roof stays snow covered much longer than before.
Dave Sal is offline   Reply With Quote
Old 03-31-2013, 08:57 AM   #8
AHH, SPANS!!!
Rewards Points: 1,166
I've installed the 8" x16" soffit vents on many houses in my area back in the 90's. measure the entie length of overhang and divide by the spacing chosen between the soffits, usually 6 to 8'. Now I know that continuous soffit is way better and can be installed to the outer edge of the overhang near the fascia. have to get into the attic (or reach up in after cutting soffit) and make sure that the rafter bay is open for air flow (baffle boards) or else soffit vent is useless and of course a ridge vent will need to be cut in at the ridge as well. installing vents in overhangs taught me the importance of a good walkboard and ladder setup and a face mask and goggles, there is no telling what is falling out of the soffit after you cut into it and yank it down
hand drive is offline   Reply With Quote
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 01:48 PM
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
