Old 03-16-2005, 06:46 PM   #1
Undercut footer
I had the old galvanized water line replaced with copper, but now I have an 8-foot section of concrete footer with no support underneath. I'd like to do it myself (since I'm out 5 grand already) and was thinking about 1) Compacting the soil beneath the footer and 2) placing concrete piers beneath the footer with adjustable jacks/screws to support the footer. Any thoughts? Suggestions?
billinak is offline   Reply With Quote
Old 03-16-2005, 06:55 PM   #2
Undercut footer
See if you can find a 'flowable fill' supplier in your locale. It costs about the same as concrete but does not require consolidation and does not shrink upon curing. Fill the void to the top of the footer and forget about it.
PS- Make sure to ask the supplier if there are any reactivity issues in regards to contact with copper.
pipeguy is offline   Reply With Quote
Old 03-17-2005, 01:00 AM   #3
Contractor
Undercut footer
You can always isolate the copper pipe. Wrap it in roofers felt will do.
Teetorbilt is offline   Reply With Quote
Old 03-18-2005, 07:34 PM   #4
Undercut footer
Sounds good. There's a flowable fill guy at Anchorage Sand and Gravel so it sounds like the way to go (after breakup that is). The copper pipe is at about 12 feet so I don't think the fill will even come close to it. Thanks for the tip!
Footer depth? levenalee Building & Construction 3 01-24-2007 06:27 PM
Brick and block house footer question. ourzoo Building & Construction 2 07-01-2006 03:57 PM
Carport Conversion - wall footer issue cybercelt Building & Construction 21 10-29-2005 04:46 PM
