Under Porch Cold Room - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-05-2011, 09:29 PM   #1
Hi All,
There is some framing and plywood located in my cold room under the front porch. Can I remove the framing I'm assuming was used to form the concrete?
bioload is offline   Reply With Quote
Old 10-05-2011, 09:50 PM   #2
Rewards Points: 6,652
Probably. How old is the home?
Old 10-05-2011, 09:52 PM   #3
The house is 5 years old....was ther since day 1
Old 10-05-2011, 10:50 PM   #4
Then why the hell wasn't it removed? Was everyone waiting for the magic fairies riding unicorns jumping over rainbows, with Pots of Gold at the end of them.
Old 10-06-2011, 10:48 AM   #5
lol.......That must have been some rainbow .....they also forgot to place a vent cap on the hole they cut in the roof for my bathroom fan.
Old 10-06-2011, 11:54 AM   #6
How many others in this development if the home is in a suburb, did this contractor and their sub's just go "Oops", and figured that no one will notice. That is why I like my older home. It was done with craftsmanship, and will be around for probably another hundred years, unlike the stuff they build today.
Old 10-06-2011, 12:15 PM   #7
DIY staff
Rewards Points: 7,174
If I'm seeing this correctly--NO--that wood gunned to the concrete looks like a ledger of some kind to hold up the 2x4 joists---
AGWhitehouse (10-06-2011)
Old 10-06-2011, 12:57 PM   #8
AGWhitehouse's Avatar
Looking ledger like to me as well...
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 10-06-2011, 01:41 PM   #9
Above the 2x4's and plywood is the concrete slab for the front porch. I've left a message with the builder and witing for them to get back.
Old 10-06-2011, 01:46 PM   #10
DIY staff
Well----best info will come from the one that designed and built it---
Old 10-06-2011, 02:47 PM   #11
Unless he poured in a fabric of rebar and wire mesh along with a slab thick enough to make that span, that wood is acting as a supporting deck. It is funtioning the same as, and probably should have been, a fluted metal deck, but I'm assuming alot of that wood was left overs already on site.
Here's a visual example of a typical concrete deck system. I'm assuming the wood structure you have is acting in place of the fluted metal decking: http://swirnowstructures.com/images/md2000beams.JPG
Old 10-07-2011, 02:38 PM   #12
Thanks all for your help.......Build informed that I can remove them, they were used as a form and usually come out once the concrete has cured.
Old 10-07-2011, 03:03 PM   #13
Look at it this way, you got some wood to burn.
Old 10-08-2011, 06:00 PM   #14
Knucklez's Avatar
Rewards Points: 942
we'd love to see your construction of the cold room. keep the pics coming and good luck with your project!
Knucklez
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Old 10-08-2011, 10:15 PM   #15
Rewards Points: 410
Tornado country Heh ?
I've dodged 3 in the last 4 years here ..closest was a mile and the others were within 5 miles.
I say leave it in place for exta support.
I saw on TV last spring I believe where a EF5 had lifted the slab and it slid into the "cold room".
The downside of leaving it in is a potential food source for mold.
If your porch is covered and on the lee side of most prevaling weather
theres much less chance of water getting though.
High Gear is offline   Reply With Quote
Cold Storage Room Help Gwen4280 Building & Construction 12 08-07-2011 12:34 AM
Cold storage room justuschickens Building & Construction 1 07-26-2011 07:19 AM
Water buildup under vapour barrier in cold room jimboat Building & Construction 11 03-24-2011 12:52 PM
Insulating basement cold room. blizmore Building & Construction 0 10-14-2010 04:02 PM
cold room under rear balcony peppstor Building & Construction 1 06-29-2010 06:08 PM
