Under Plywood - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-19-2013, 06:22 PM   #16
Rewards Points: 81
That sounds like a squeaky floor with a lot of cracked tiles...
one cut is offline   Reply With Quote
Old 04-19-2013, 06:28 PM   #17
So thicker nails then? What would work best?
busyhammer is offline   Reply With Quote
Old 04-19-2013, 07:01 PM   #18
8d through a 2x?
So like 10d?
Old 04-19-2013, 07:41 PM   #19
Roofmaster
Rewards Points: 2,172
You are going to want to put down felt first, then your 2x's, and I would screw everything down.
Old 04-19-2013, 08:40 PM   #20
Rewards Points: 13,444
Why would you use felt between a 3/4 subfloor and the 2 X 4?
Old 04-20-2013, 10:19 AM   #21
Rewards Points: 81
your best bet would be using subfloor glue and screws.
Old 04-20-2013, 01:17 PM   #22
Any specific screws I should look for?
Old 04-20-2013, 05:02 PM   #23
Rewards Points: 81
no, any 3"-ers would be fine
lay vinyl tile on patched holes in plywood charotte Flooring 5 10-25-2012 07:59 AM
How to attach plywood to subfloor Billdd Flooring 6 08-05-2012 04:27 PM
Can I tile over old plywood with no gaps? JFERTICH Flooring 5 02-21-2011 02:52 PM
Can I use Thin Set Mortar over Interior Grade Plywood? JFERTICH Flooring 1 02-19-2011 05:08 PM
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-13-2010 11:09 PM
