Under Pinning A Wet Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-16-2011, 07:08 AM   #1
under pinning a wet basement
under pining a wet basement, i want to low my 80+ years old house basement floor to be 8' now is 5.5, how can i,
jer
je ruiz is offline   Reply With Quote
Old 08-16-2011, 07:46 AM   #2
Rewards Points: 1,668
I think this is the time to pull out the check book. I've seen it done on TV and at minimum you need an engineer to give you the specs of what would need to be done to safely underpin the foundation. After that, you've literally tons of dirt to remove and then laying in the new concrete work, all without having the existing foundation not fail. Good luck with the project.
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
je ruiz (08-17-2011)
Old 08-17-2011, 07:10 AM   #3
Thank you Bob i am talking with an architect,
as far as the work i like to do it my self if is possible.
Will see if i can get some help but my budget is low.
good day.
je ruiz
basement causing suction on basment door BlueBSH HVAC 3 06-08-2010 02:26 PM
Basement Cooling BTU requirements? neilt HVAC 5 05-29-2010 03:26 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 06:50 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
