Under Deck Ceiling Ideas Or Thoughts? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-02-2011, 08:10 PM   #1
TBW
Under Deck Ceiling ideas or thoughts?
I built my new deck last year nad want to start utilizing the space underneath it. My deck material is Geodeck composite, Geodeck told me that I can use an "underdeck" type system without voiding my warranty. Instead of paying the higher cost of the underdeck system, I was going to use steel roofing with the white side down to add some light to the area.
Here's a video of someone doing something similar to what I'm thinking except I would run the angle mounting boards for the roofing the other way.
I'd appreciate any how-to's or comments or suggestions on my idea.
Thanks in advance.
TBW is offline   Reply With Quote
Old 06-03-2011, 10:28 AM   #2
Rewards Points: 508
I guess I don't care for the look of the corrugated vinyl used in the video, especially with the exposed edge. It doesn't look finished to me. I believe the Underdeck system is integrated with a gutter. I suppose you might be able to terminate your home-made system with a piece of Azek trim, and attach a piece of gutter to the inside to achieve a similar effect.
benjamincall is offline   Reply With Quote
Old 06-04-2011, 07:30 AM   #3
TBW
As I mentioned, my thought was to use steel roofing panels. I thought I would trim it off nice too with some sort of end cap.
Redecorating DD's room....thoughts, ideas? Looong. RealHouswifOfOK Interior Decorating 14 04-22-2011 06:19 PM
Deck Railing and Skirting Ideas Ruger141 Building & Construction 0 05-05-2010 09:52 PM
Need advice on deck flashing, water stain Durt Ferguson General DIY Discussions 4 04-20-2010 05:09 PM
Ceiling Ideas....? SGTHetland General DIY Discussions 3 08-12-2008 05:39 PM
Thoughts on TWP deck stain/sealer? gernith General DIY Discussions 1 05-19-2008 08:37 AM
