Old 10-28-2012, 10:08 PM   #1
under cabinet range hood
Iam installing a kitchen in the basement,just purchased a under cabinet range hood to be vented outside it calls for a 7inch ducting.It will be going straight up through cabinet tahn through the dropped ceiling,than going between ceiling and upstairs floor than out.It would help if we could take this to a 6 inch vent is this possible?
rickag is offline   Reply With Quote
Old 10-28-2012, 10:28 PM   #2
DIY Enthusiast
sublime2's Avatar
Absolutely!!
sublime2 is offline   Reply With Quote
Old 10-28-2012, 10:30 PM   #3
If the manufacturer's specifications call for a 7" round duct then you lose venting efficiency when you reduce the duct size. The installation manual will usually specify the maximum length of the run and number of change of direction you can make. e.g. it may specify a maximum run of 18' and deduct 5' for each 90 degree bend. If you have a long run or changes of direction you would not want to also reduce the duct. You can get an adapter to go from round to rectagular if that helps you keep the proper flow. e.g. 6" round equals 3 1/4" X 10" rectangular. I hope this has been of some help. good luck.
TheCamper is offline   Reply With Quote
The Following User Says Thank You to TheCamper For This Useful Post:
rickag (10-28-2012)
Old 10-28-2012, 11:32 PM   #4
yes,i believe that will work we will check into this further
thanks for info
range hood opening is bigger than range hood jacks16 HVAC 2 06-23-2011 07:19 AM
Backdraft, Cold Air and Ice from Range Hood and Bath Fan Passion4Heels HVAC 13 08-19-2010 08:00 PM
Alternative to range hood fan Richo HVAC 2 04-11-2010 03:43 PM
Built in cabinet range hood Richo Electrical 3 03-24-2010 11:10 PM
Cabinet Crown Molding and Hood Range? gate1way2 Carpentry 3 10-16-2008 12:13 AM
