Unattached Porch Post - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-08-2015, 05:27 PM   #1
Rewards Points: 4,796
Unattached porch post
This rail is not as secure as it could be - when pressing on it, it bends out. It could be the post on the outside is not well secured to the brick. Or, it could be the post sitting on top of the brick should be attached.
My first thought was to cut out the rails to the near post, bolt one of those metal plates to the brick and attach with cement anchors, set the post on the plate, and reattach the rails.
Does this sound like a good idea?
jeffnc is offline   Reply With Quote
Old 01-08-2015, 05:56 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,088
Ayuh,... Or you could screw a short metal tab onto the front lower bottom of the post with screws, 'n the other end of the tab tap-coned into the brick face under it,....
Steel angle brackets could be used, screwed, 'n tap-coned,...
Old 01-08-2015, 06:12 PM   #3
kwikfishron's Avatar
Rewards Points: 434
Bingo.....If the outside post and the post at the bottom of the stairs are solid then the post you pictured isn't going anywhere. Any topside attachments you may try at the base of that post won't solve the problem.
kwikfishron is online now   Reply With Quote
Old 01-09-2015, 03:59 PM   #4
So it sounds like a couple long Tapcon screws through the side posts into the brick porch would be my first try. I could also use brackets as first suggested, I'm just not crazy about it aesthetically.
Old 01-09-2015, 04:35 PM   #5
Rewards Points: 13,472
Trying to attach post to a brick step like that almost never works, and the post rot out.
They should have been installed no Strong Tie post bases.
I use post set in concrete on the outside of the steps.
In your case if you used aluminum angle with at least 3, Tap cons per side and added PVC lumber as post bases with vinyl cove moulding or vinyl base cap moulding to deflect the water way from the base cap and cover up the aluminum angle it would look OK.
Old 01-09-2015, 04:42 PM   #6
Knowing what's beneath the brick is half the battle.?
ron45 is offline   Reply With Quote
Old 01-09-2015, 05:54 PM   #7
Rewards Points: 434
I'd say more than half....Once you have the answer to that question the solution spells itself out.
Old 01-09-2015, 08:57 PM   #8
Why do you say that? Im not going to be going all the way through the brick..... dont get it.....
Old 01-10-2015, 12:02 PM   #9
Rewards Points: 434
I wouldn't trust brick as an attachment point for a guard rail for all of the same reasons we don't attach deck ledgers to brick either.
Old 01-10-2015, 12:25 PM   #10
So are you saying I would want to drill all the way through the brick and into the concrete/cinder block inside? That would require quite a long anchor bolt - do they make them that long?
Old 01-10-2015, 02:44 PM   #11
Rewards Points: 434
Myself anyway can not give you a solution based on that picture, too many variables.
Don't know the condition of the brick, Is the block hollow or filled?
The corner post appears to be notched, how much meat is left? How far down does it go, one brick or to the ground?
How much movement are we really talking about here?
When it does move, whats actually moving, loose fasteners, split post at the notch, is the brick moving with it?
Or is the corner solid and the post at the top of the stairs is just lifting?
What's the budget?
Need to replace rotten wood support post on porch cdnNick Building & Construction 33 05-14-2013 04:30 PM
Post base for wood porch Quercus Building & Construction 2 07-22-2012 02:43 PM
Porch Flooring Recommendation RyanS. Flooring 0 04-16-2011 11:31 AM
porch post ideas wombosi Building & Construction 2 03-26-2010 09:05 PM
Attaching Porch Post to Foundation Earnie Building & Construction 4 03-15-2010 08:38 PM
