Originally Posted by Jeekinz
.... If the original floors are too far off level then I will straighten them out.
What obstacles could I encounter by removing the floor they installed?
None that I am aware of...tho, you just never know how they installed that floor. Example: Maybe they could have used tons of construction adhesives...?
Also, at one end of the room is a 6' x 15' addition (basically a bump-out with non accessible crawl space) When they installed the foundation for the addition, would they have met the height of the original foundation or not?.
Again, I can't tell you whether they did or not. Not all additions are attached to meet the same floor height of the existing structure. (they are usually even to it or a step down....)
It is actually common for new structures which are added onto or attached to older structures to have a step down (to increase head room/height), since the ceiling heights of older homes are not adequate by today's standards...
If they built the new section of foundation to accomodate the height the floor is now, I would have to lower the floor joists.
As mentioned previously, I would not worry about stepping down to an addition, that is not completely unusual. It's stepping up that seems/looks/feels - strange....
