Old 01-27-2009, 01:49 PM   #1
Tyvek with Spray Foam Insulation, Yes or No?
Since spray foam insulation apparently acts as a vapor barrier, is it then not necessary to install Tyvek housewrap on the exterior sheathing? Would it actually be a bad idea to install it, since any moisture in the wood would have nowhere to go?
If no Tyvek is required, should any barrier be put on before vinyl siding?
This is wood construction, not steel.
Zinger is offline   Reply With Quote
Old 01-27-2009, 02:22 PM   #2
"since any moisture in wood would have nowhere to go?" Where did you read that Tyvek is vapor impermeable???? It is.
Josh Jaros
jaros bros. is offline   Reply With Quote
Old 01-27-2009, 02:35 PM   #3
Jer
Is the spray foam insulation you refer to just around windows and other penetrations or on the complete exterior?
Jer is offline   Reply With Quote
Old 01-27-2009, 03:20 PM   #4
It is vapor permeable. I think it is around 50 something perms so you will have no problem.
Josh Jaros
Old 01-27-2009, 05:23 PM   #5
tyvek is not a vapor barrier and is never used as one. In cold climates the vapor barrier goes on the inside (warm side) of the insulation. If you are using a closed cell foam that genuinely acts as a vapor barrier then you don't need to and shouldn't add another one on the inside.
Tyvek is called a weather barrier by some folks but that is different than a vapor barrier. Tyvek is suppose to stop air infiltration and liquid water but is suppose to allow water vapor through. So go ahead with the Tyvek to protect your sheathing from liquid water - it is suppose to allow moisture to evaporate through it.
Old 01-27-2009, 05:42 PM   #6
SNC
you should ALWAYS use a weather barrier behind your siding, ANY siding.
SNC is offline   Reply With Quote
Old 01-27-2009, 08:50 PM   #7
Professional Wood Shafter
ryanh's Avatar
Always use a housewrap on your exterior for increased water and air resistance you don't want water getting behind your siding and running down your sheathing
ryanh is offline   Reply With Quote
Old 01-27-2009, 10:46 PM   #8
Tell that to T.H. Properties (Major builder in my area). Those cheap SOBs not only will put siding over bare sheating, but if you elect for Tyvek they won't even tape the seams. Oh, and they don't Tyvek any unheated exterior surfaces like garages or roof peaks (apparently they don't know that Tyvek let's vapor through either).
It's sad what passes for construction sometimes.
Thanks guys.
Old 01-28-2009, 09:34 AM   #9
Tom Struble's Avatar
The tyvek becomes the drainage plane that keeps bulk water from damaging your sheathing
Tom Struble is offline   Reply With Quote
Old 01-28-2009, 05:29 PM   #10
Zinger, Go to the tyvek site and look under residential FQA section for renovators and contractors. It will help a lot.
Chemist1961 is offline   Reply With Quote
Spray foam insulation troyce1 Building & Construction 9 05-24-2011 07:57 PM
spray foam insulation mikeybobo Building & Construction 11 06-19-2010 05:04 PM
Air cavity required behind spray foam roof insulation BigJimmy Building & Construction 9 06-08-2008 01:45 PM
Spray in foam insulation leted_82 Building & Construction 3 05-31-2007 11:14 AM
