Tyvek And Roofing Felt - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-08-2010, 06:20 PM   #16
kwikfishron's Avatar
Rewards Points: 824
There will be a class action suit some day. Hope I’m around to cash in on that one.
Thanks again LP.
kwikfishron is online now   Reply With Quote
Old 05-09-2010, 01:52 PM   #17
Tom Struble's Avatar
Rewards Points: 2,002
every thing that was said about seeing moisture under a plastic wrb Ive seen also under felt,I've seen felt rot and get brittle under siding also
alot that has been said about early versions of tyvek are not necessarily true now
that being said i can't fault anyone for relying on a tried and true material like felt
Tom Struble is offline   Reply With Quote
Old 05-26-2010, 03:00 PM   #18
Rewards Points: 264
Is this what you are referring to as felt wrap?
http://www.homedepot.com/Building-Ma...atalogId=10053
how do you seal seams of felt? Or do you just overlap layers from the bottom up?
What about Weathermate Plus Housewrap? Better/worse than tyvek and/or felt?
Good thread!
moneymgmt is offline   Reply With Quote
Tyvek fasteners?? justdon Remodeling 1 03-02-2008 12:19 PM
