Old 01-22-2009, 03:15 PM   #16
BUILDER / REMODELING CONT
buletbob's Avatar
tyvek over wood or foam insulation
No not at all. From what I have been reading on this site there is a good experience contractor up your way that I believe is a mediator on this site who would be more inclined to answer your questions of building practices in your state, you might be able to give him a private massage. Atlantic Construction is his user name. Best of luck, and any other questions I will be more then happy to discuss with you. BOB
Old 01-22-2009, 03:38 PM   #17
If he won't accept a private MASSAGE don't worry, send him an email intead!
Chemist1961 is offline   Reply With Quote
Old 01-22-2009, 04:06 PM   #18
Remodeling Contractor
Swith 1 and 2... the house wrap goes over the window flashing. Remember top down, water understands gravity.
Old 01-23-2009, 01:05 AM   #19
Tom Struble's Avatar
you should consider foam underlayment as an extension of the sheathing and pack out your windows the same thickness of the foam.
then you can integrate the window flashing to wrb properly tyvek
should always be directly under the siding
Tom Struble is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Ready to paint the porch! Oil or latex? Leah Frances Painting 8 07-26-2011 08:29 PM
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 10:39 PM
Tyvek application in crawlspace libwes Building & Construction 3 03-27-2008 12:45 PM
