TYVEK- Over,--or Under 1/2" Foam Board For Residind With Vinyl In NH - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-27-2010, 07:52 AM   #1
TYVEK- over,--or under 1/2" foam board for residind with vinyl in NH
Hi-I'm siding my 55 year old house in NH and want to add 1/2 board over the t&g sheathing before the viyl-but unsure as to whether to put the foam over,or under the moister shield-thanks,A
Albie's is offline   Reply With Quote
Old 07-28-2010, 01:43 AM   #2
Rewards Points: 1,092
search on greenbuildingadvisor.com, and i believe you will find that the tyvek goes on the outside of everything. that is what my memory recalls, fwiw. also, be sure to tape/goo the edges of the foam sheets. j
wall sheathing, foam board, insulation and house wrap dr.demento Building & Construction 10 10-18-2007 04:42 PM
Stone veneer over foam board. rfjm58 Building & Construction 6 04-10-2007 06:40 AM
Best Ext. Sheathing: Rigid Foam An Option? austinbirdman Building & Construction 3 12-15-2006 09:02 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
