Tyvek ??? Or Nothing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-12-2012, 08:26 PM   #1
Tyvek ??? Or nothing
Hi all.
In the next few weeks I will be taking down all of my old bricks on my house ( long story) and putting up new ones.
At the same time I will be changing all of my windows.
I'm almost certain that my '72 built house has exterior grade drywall behind the bricks and I live in Canada. Toronto to be exact.
Should I be wrapping my house in Tyvek before the bricks go back up ??
Should I change the drywall for plywood or would I be okay keeping the drywall ??
Ryansoho is offline   Reply With Quote
Old 04-12-2012, 08:39 PM   #2
Rewards Points: 13,458
If it was my house I would remove it all go over the wall with OSB and then the tyvec.
Drywall as almost no shear strenght compaired to real wood.
Would give you a far more solid surface to attach the window flanges to.
Old 04-12-2012, 08:44 PM   #3
Concrete & Masonry
Rewards Points: 548
I would never recommend Tyvek directly behind brick, unless you're in an arid region, which you obviously aren't. The lowest cost approach would be to add 30# tar paper over the sheating, lapping adequately & flashing properly at every penetration. Be sure to allow a decent airspace (1" min. here) between the brick & backwall and weeps above grade at the base, as well as air vents at the top.
jomama45 is offline   Reply With Quote
Old 04-12-2012, 11:17 PM   #4
Rewards Points: 1,092
I'd skip any OSB and use plywood. OSB and any leak may get ugly.
Old 04-12-2012, 11:43 PM   #5
I see both of you points.
My thinking is from what I have seen when doing remodeling the walls could not breathe when someone used tar paper instead of Tyvek and the inside of the walls molded up, or the wall studs rotted.
It's common to see tar paper used and most often it worked out fine but if there's high moisture under the home, not enough venting under the home, not enough venting in the roof ect. it can cause a problum.
I do mostly remodeling not new constrution so I often get to see what happens years later.
Not sure what differance it would make if there's a wall leak, both will fail.
Not an agrument just a differance of opion.
Old 04-12-2012, 11:59 PM   #6
joe: tar paper has a perm rating that is very high, or fairly low. I just copied this from http://www.greenbuildingadvisor.com/...elt-astm-d-266
"Asphalt felt has a permeance of only 5 perms when dry, but a much higher rating of 60 perms when wet. Fans of felt note one of its advantages over housewrap: If water gets behind felt — either due to a flashing leak or condensation from solar-driven moisture — the felt can soak up the liquid water and gradually dry to the exterior." Some of the cats mentioned here (Hollady, Straube, etc) know an H of a lot more than me, and I have come to trust them over the years. Variable permeability was a new concept to me until I read this (and other, similar statements). Membrain is a newer product that allegedly does the same thing; a "smart" vapor retarder. If there is damage w/ asphalt felt on a wall, I would suspect there was an inherent design/build issue that would have caused anything to fail. Felt has been around, and working well, for ions. Just my two cents on the deal. I am sure you see and try to repair some serious disasters! Good luck.
Old 04-13-2012, 05:26 AM   #7
Wow. Thanks.
Alot of info here.
What's about on the exterior drywall issue.
Should I remove it and replace it with plywood, should I put plywood right over it. Or could I just leave it and rebrick ??
Old 04-13-2012, 11:43 AM   #8
I am not familiar w/ "exterior drywall" but like Joe said, it ain't plywood when it comes to structural strength, if it is in fact gypsum-based.
Old 04-13-2012, 01:29 PM   #9
Chicago, IL
Michael Thomas's Avatar
I inspect leaking masonry buildings here in Chicago for a living.
IMO, 1) proper detailing at horizontal surfaces and wall penetrations, 2) the creation of an unobstructed and properly ventilated drainage plane and 3) the selection of appropriate masonry materials and their correct installation is *far* more important than the choice between any of the acceptable vapor retarders.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 04-13-2012, 05:33 PM   #10
Registered User
Rewards Points: 5,498
Leave the GypRock be, it is better than wood let-in braces alone, and equal to a steel strap-braced wall. Table 4;http://www.fpl.fs.fed.us/documnts/fplrp/fplrp439.pdf
Taping the joints, panel orientation, and fastener connection all have an influence on its racking strength.
OSB or plywood panels are much better for racking resistance for high seismic areas; http://bct.eco.umass.edu/publication...n-the-outside/
Another option is replace just the minimum (corners, etc.) to resist a 90 mph wind; http://www.awc.org/pdf/WFCM_90-B-Guide.pdf Check with your local AHJ.
I'd go; cc foam board--- h.w.(stucco wrap)/paper (2 layers)---existing GypRock----- no f.g. unless existing---v.b. if required (which would reduce f.b. thickness)---- drywall
F.b. over the HW to prevent air-billowing/construction damages, no OSB, intact drainage plane.
http://www.buildingscience.com/docum...ting-sheathing
Gary
Old 04-13-2012, 06:08 PM   #11
Concrete & Masonry
Rewards Points: 548
All of those things are certainly important, but the evidence is prevailing that solar-driven moisture really is a big problem for today's residential masonry veneers...........
Tyvek, Insulation or both BirmJam Remodeling 9 04-15-2012 11:54 PM
tyvek question roughsawn General DIY Discussions 11 03-03-2011 08:00 PM
Stucco contractor cut up all my Tyvek! What to do? Gatorback Building & Construction 9 10-20-2008 05:43 AM
Tyvek application in crawlspace libwes Building & Construction 3 03-27-2008 11:45 AM
Tyvek RickT Building & Construction 4 03-15-2007 06:06 AM
